please need km correction for this file
need adjust 162.000
i tested other file 162k and lcd flashing
dashboard eprom 93c56
please help
need adjust 162.000
please help
Strange.Your dump is OK. Check soldering
thanks i tested soldering
is same lcd flashing
need to do bsi, behind glove box
thanks for your help I have made several kilometers and the lcd always blinking
regards
its posible bad eprom microchips???
no,........do dash,read dash,note kms on dash,then do bsi,enter dash kms in bsi
post dump from bsi unit should be a 68HC11P2 chip
the pdf to that car is to do the cluster and to do the bsi.
if you only do the cluster, the cluster will blinking for eternity because they not have the same milleage like bcu
you must put the same milleage at bcu and cluster
so do the cluster connect cluster to the car and see the milleage, because that cars have a read mistake the +- 500kms
then take bcu out programme with the same milleage and then the cluster stop blinking
it?s easy only need to follow the pdf......
the bcu is not a easy job but........
nothing is easy at our live ahahah
i hope can clarify .....
i post pdf to the bsi
ciptel07 (8th October, 2013)
