Hi mates,
After disable the passenger seat sensor in a w211 with Das developer and clear all faults the red light in the dash and SRS advice still on.
The car have no faults.
what I forget?
Anyone can help?
Thanks for any help
Hi mates,
what I forget?
Anyone can help?
Thanks for any help
Have you disconnected the connector under the seat?
Solved with the great help of MR. ljbp.
A BIG THANKS to him.
I went down this road once..could never get it to work w/developer..Ended up getting a simulator..Would be nice to know the procedure to do this?
Kind Regards, and remember > Any information provided is for educational/experimental purposes only.
Using DAS DEVELOPER, in airbag special functions, set off the seat sensor, then unplug the conector of the seat sensor,otherwhise you will get an Incorectly coding airbag fault, and light on dash too.
dont talk a lot and nothing
In das dev. mode variant coding sbse/akse off i think dont rimember now and unplug or cut seat sensor under the pass. seat then erse fault codes 2 times
