Results 1 to 4 of 4
Thread: Birlingo
    Apr 2010
    Default Berlingo
    I have a citroen birlingo with air bag faults = passengers deactivation switch & ecu dataB wire short /ground . This van has no passenger airbag and was not ever crashed. i scaned with lexia & in configaration it has no pass airbag! Has anyone met this before?
    Apr 2010
    Portugal
    DK Veteran juniormaxxx's Avatar
    Aug 2010
    croatia
    buy lexia and try changing configuration, check the wires from SRS module, and if nothing work change dump from SRS module....it probably is a fault in module
    If I was usefull be sure to thank me.......if I was not just do nothing, I can shot lighning and use mind tricks through internet........yea i can....
    Apr 2010
    Thanks for ideas guys! found problem may help others corroded /broken dataB wire @ engine ECU! hope this helps others
