Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Thread: 206 Non Start
  1. #16
    gejzaslapka's Avatar
    Aug 2009
    somewhere over the rainbow
    take a photo inside the ECU and place it here please
    gs
  2. #17
    Ashraf6119's Avatar
    Nov 2009
    UK
    Quote Originally Posted by gejzaslapka View Post
    gs
    OK will do that on Tuesday .............
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
  3. #18
    Senior Member EssexTech's Avatar
    Mar 2010
    Enter the code into the BSI then releran the keys. When it says no communicating with Engine ECU does it say remote or local.
    HYUNDAI AND PEUGEOT TECH
  4. #19
    Meat-Head's Avatar
    HI
    ONLY JUST SEEN THIS THREAD.
    THAT FAULT THAT CAR, THE FIRST THING YOU DO.
    THE LOOM FROM THE FRONT OF THE FUSEBOX OVER THE BELLHOUSING, REMOVE THE PLASTIC CASING, ABOUT 9 WIRES FROM MEMORY, RED AND YELLOW - CLOSE EYES AND YANK.
    WE HAD ONE ABOUT A YEAR AGO, IT RESISTED BEEN YANKED 4 DIFFERENT TIMES - HARD, ECU HAD BEEN SENT AWAY ETC ETC, SEE ON SOME INFERIOR WEBSITE ABOUT HOW SOMEBODY HAD 3 WITH SAME ARROGENT FAULT.
    GOT THAT PISSED OFF WITH IT, JUST REALLY REALLY YANKED VERY VERY HARD ON ALL THEM WIRES, THEN LE SNAP, GREEN WIRE, BUT IT HELD SOLID, REALLY REALLY PISSED OFF AT THIS POINT, LE SCOTCH LOCK, FIRED UP INSTANTLY.
    ANNOYING THING WAS THAT WAS THE FIRST THING WENT TO WHEN IT CAME IN. AND THE COSTOMER HAD HAD A GOOD TUG AS WELL IN THAT AREA.
    WE MUST HAVE BEEN 12 HOURS OFF-LINE DOING IT, EVEN "PRETENDED TO HELP ANOTHER COSTOMER" BY PLUGGING IN IT'S NOW UNLOCKED ECU.
    HTH
    MEAT
  5. #20
    Ashraf6119's Avatar
    Nov 2009
    UK
    Quote Originally Posted by EssexTech View Post
    Have not yet tried hopefully will try that and let you know........... Remote or, Local......What does this mean..............
    Thanks Ash
  6. #21
    Meat-Head's Avatar
    Quote Originally Posted by Ashraf6119 View Post
    SPEEDO SAY SAY SAYS "SPEED SENSOR - REMOTE"
    ~~~~ING PHONE IF A SPEEDO HEAD SAYS "SPEED SENSOR - REMOTE"
    ASSUME ABS IS TELLING IT HAS LOST A WHEEL.
    ABS WILL SAY "WHEEL STOLEN -PERMENT"
  7. #22
    Mar 2010
    PMSL .........
    Remote fault means a control unit has detected a fault further down the can bus/cabling. Local is nearer to home. Coherance is a good one which means the circuit is ok but the reference value is not correct
    Peugeot Planet is one of the best dealer tools i have used..
  8. #23
    Ashraf6119's Avatar
    Nov 2009
    UK
    Quote Originally Posted by oldford View Post
    Do you get 5V power to the various sensors?
    Coolant temp, intake air, throttle position?
    When no, the ecu is not powered up.
    What's the voltage level on pin 7 of the DLC?
    Oldford,
    I got good Battery Voltage at Pin 7............
    Thanks Ash
  9. #24
    Sep 2009
    If it's really good (equal to battery voltage) chances are you have a short circuit to plus.
  10. #25
    Meat-Head's Avatar
    or ecu dropped it's earth
  11. #26
    Meat-Head's Avatar
    HI DID YOU FIX THISYET?
  12. #27
    Meat-Head's Avatar
    Can you tell what it is yet?
  13. #28
    Ashraf6119's Avatar
    Nov 2009
    UK
    Replaced with another ECU set and its gone long time ago mate................
    Thanks Ash
