Page 1 of 19 12345611 ... LastLast
Results 1 to 15 of 280
    UK
    Default Epson SX125 waste ink counter reset
    Hey guys,
    It took me ages to source a SX125 waste counter reset program that works, so I thought I would pop it on here.
    I've uploaded it into the download section, but thought I may as well pop it on here with a bit of guide too.
    I've only tested it on XP 32bit, with a UK SX125 printer, so that's what the instructions will be tailored for. By all means try it on other OS's and feel free to post results.
    Reset instructions for SX125:
    • Install printer if not already installed.
    • Download and extract attached file into a folder on your hard drive.
    • Run 'AdjProg.exe' and click 'Accept' on the splash screen then click on 'Select' at the top.
    • From the pull down boxes, select 'Epson Stylus TX121' for 'Model Name' and 'ESP' for 'Destination', click 'OK'.
    • Click 'Particular adjustment mode' then from the '---- Maintenance ----' section, select 'Waste ink pad counter' then click 'OK'.
    • Click 'Check' on the bottom right, this will query the printer and give information of ink shots and so on.
    • Tick the two boxes on the left, 'Main Pad Counter' and 'FL Box Counter', then click 'Initialize'.
    • It should come up with a message abut restarting your printer, do it!
    Job done, carry on printing!
    I recommend getting a waste ink tank for your printer, have a Google for one, the waste ink pipe is easily accessible from a clip in hatch on the back of the printer.
    Hope that helps, if it's useful, don't forget to thank
    J.
    right, rubbish is still being posted to gain access to this file even after a warning, i will say this one more time, DONT KEEP POSTING RUBBISH TO GAIN ACCESS TO THIS FILE, keep your posts to questions or an answer to another post, THE NEXT PERSON WHO POSTS.....THANKS OR GOOD POST OR JUST WHAT I NEEDED OR ANY OTHER RUBBISH TO GAIN ACCESS TO THIS FILE WILL BE BANNED, YOU HAVE BEEN WARNED !!! DK STAFF
    YOUR FIRST POST GOES HERE-----> http://www.digital-kaos.co.uk/forums/f2/
  2. The Following 61 Users Say Thank You to johnnybeast For This Useful Post:
    atelzut (9th October, 2014), balibee (20th May, 2013), bertione (29th January, 2014), boaaar (24th October, 2013), c2804021 (15th December, 2013), coldblue (28th May, 2013), dpodor12 (19th November, 2013), ebalkiss (12th November, 2014), eddyvankenoby (22nd January, 2014), FalconMigz (2nd September, 2014), ferrasur (6th January, 2015), fiat 0000 (25th October, 2013), fischman (2nd June, 2013), hamito (29th July, 2013), haveitdave (2nd July, 2014), hrv (7th July, 2013), isiemelink (18th September, 2013), ivanpricic (19th April, 2013), josej69 (3rd May, 2020), korgao (20th April, 2014), lambrosg22 (18th November, 2013), Leitxo (29th October, 2013), magestery (21st October, 2013), Malcolm974 (13th May, 2013), Manhunt (24th June, 2014), mark2024 (25th February, 2024), marsarts (21st October, 2015), masterren44 (3rd April, 2014), metak (21st December, 2016), murch (8th April, 2014), musta22 (23rd April, 2022), northernheart (22nd October, 2013), PCMEDIC (30th September, 2014), pippo3210 (7th February, 2024), protor (15th January, 2015), ps2k (24th November, 2015), ptolemaeus (28th March, 2013), sbixx (7th April, 2013), shevor (8th March, 2019), shuffleinc (12th August, 2013), sidwho (15th May, 2013), sumpy (7th July, 2014), telecomonde (19th June, 2013), thessgr (26th June, 2013), tony18101963 (25th May, 2013), tr0r (30th June, 2014), xxhd (28th June, 2014), yiwen akeni (17th December, 2013)
  3. #2
    Apr 2012
    Default epson stylus sx130
    dear
    does this software work on Epson stylus sx130
    thank you
  4. The Following User Says Thank You to akramjef For This Useful Post:
  5. #3
    UK
    The reset program is just for the Epson SX125, but it might work for the SX130 as they are very similar. Other people have reported it working on the SX130. Give it a blast!!
    J.
  6. The Following User Says Thank You to johnnybeast For This Useful Post:
  7. #4
    Apr 2012
    Default hope
    hello, I'm new here.. I was searching just this software because my sx125 doesn't recognize a cartridge (that is still with ink). I hope it will work thanks
  8. The Following User Says Thank You to bel3nebroso For This Useful Post:
  9. #5
    Apr 2012
    I've done all the steps, but the problem is always the same black cartridge not recognized, but till yesterday it worked and the cartridge had some ink remaining...
    Some suggestions?
  10. #6
    UK
    Suggestions:
    1 - Are you using genuine or copy ink? If it's copy ink then theres a chance that the chip is telling the printer that the ink is empty or the chip has failed. Try changing the cartridge for a new one.
    The reason for the 'not regonised' message instead of 'out of ink' message is the sophistication level of the copy chips, they will report the level of ink but when the ink is out it comes up with 'not recognized' even if there is still ink left in the cartridge. Clever huh?!
    2 - The chip contacts in the back of the head could be corroded or bent, get a torch, take the cartridge out and have a look, if they are, pull the power out and clean or gently bend them back.
    3 - Your printer's stuffed. I've seen it happen only a few times, the microprocessor that reads the chips could be faulty, time to give yourself a treat! A lovely new printer
    Hope that helps, let me know! Always good to get feedback.
    J.
  11. #7
    Apr 2012
    thank you very much i have sx125 and it work for me
  12. #8
    Apr 2012
    Thanks so much! It finally worked after disabling my antivirus for a while. Please reach me on ( no addys ) for more talks. Thanks once again.
  13. #9
    Apr 2012
    Default Thnaks
    Thanks! I'm hoping this will reset the ink pad counters, it's telling me I need to service because I've head cleaned so many times when installing a CISS
  14. #10
    Apr 2012
    It took me ages too to source the same thing- im thankful to God that i finally bumpep onto one (A proven one most of of all). i hope to download it right away.
  15. #11
    Apr 2012
    i had a problem with my epson sx 125 but i hope you guys can help
  16. #12
    Apr 2012
    Default hey
    does this helped anyone who has copy cartridge and not recognizing the black one ... does it helped??
  17. #13
    Canker_Canison's Avatar
    12th Level of Hell
    Quote Originally Posted by zagervbk View Post
    No it won't. The black cartridge will have to be changed.
    Canker
    "Animal, vegetable or mineral... I'll do anything, to anything, with anything"
    - The Baby Eating Bishop of Bath & Wells
    [COLOR=Green]
  18. #14
    Apr 2012
    Thumbs up epson sx130 resetting
    dear Canker_Canison
    thank you for this program ,i used it for my Epson stylus sx130
    and it work fine .it reset waste ink pad counter to zero.
    so this program can be used for Epson model:
    ME320 , SX125 , TX121 ,and SX130
    good luck.
  19. #15
    V.I.P. Member andy91's Avatar
    Aug 2010
    East Midlands
    Its ok using the program to reset your counter but the reason its there is to stop waste ink overflowing and spoiling your new carpet
    Most waste ink gets held in a sponge so its worth trying to soak up any excess ink when you reset the counter.
    Andy.
  20. The Following 7 Users Say Thank You to andy91 For This Useful Post:
    darkyinlove (24th May, 2013), imrefinnej (9th February, 2014), lapvinh (17th October, 2013), sjbrit (10th October, 2014), yiwen akeni (17th December, 2013)
