I downloaded and extracted the files into a folder, however when I click select no drop down option appears.
any ideas??
any ideas??
finally i found a way to use my epson sx130 again! my magena, black and yellow inkpads are full but my cyan are almost empty (3%). and for that reason i can't print neither in black and white. it sucks
My sx130 eat ink like my car cal gasoline, so i was thinking that what is up to this crap.. i opened one "empty" ink chartige, and it was half full of ink. I really hope this works.
Hi guys, does this work for TX110?
I have an epson sx130 that lately wont recognize copy cartridges that i have used for the last 2 months without a problem. Now the printer only works with original epson cartridges. What can i do to have copy cartridges recognised again?
thunk you
hi! IS THIS COMPATIBLE WITH EPSON ME340? THANKS.
dear
does this software work on Epson stylus sx130
thank you
I am getting this message on my epson sx125 The printer's ink pads are nearing the end of their service life. Please contact Epson support. I doubt the pads need replacing. How can I reset the counter?
To all the new people on here, thank you for joining, but...
Firstly, read the forum rules.
Secondly, read posts provided by other users, once you're satisfied theres not an answer there to your query, then post a reply
Yes this software will work on the SX130, I haven't tried it, but other users have posted positive results, so give it a go!
To reset the SX125, read the first post of this topic that I posted, there's a pretty comprehensive guide on there. Read it and try it, if it works, press the 'Thanks' button at the bottom of the post. Simples.
So far this software and guide has been tested on SX125 and SX130. It probably won't work on any other Epsom printers.
J.
why give me Ink out error on SX125 ?
Would this work with SX235?
Let's see if this work for me, for some reason it doesn't see original epson cartriges.
hy Andy....im new member....i have same problem on sx 130 printer....black is low always....i replace a 3 new black ink and same thing.... i see that problem can be solved.....did you maybe know how..... thank you.....
i thought the program adjProg would be useful, but it turned to make more problems
i have sx125 but now the printer says it is tx121
under adjustment, i tried eeprom data copy and initial setting
does anyone knows how can i turn back to sx125?
