Page 2 of 19 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 279
  1. #16
    Apr 2012
    Default waste ink overflow
    dear andy91
    there is small door on the back of the printer , if you open it you will find a tube which carry the waste ink to the waste pad, disconnect it from the pad and connect it to out side waste ink container ( do-it-yourself). this is what i did to my printer and till now there is no single drop of ink on the pad.
  2. #17
    May 2012
    thank you
    it is working
    model sx125
    a little pdf guide with images...
    download here
  3. The Following User Says Thank You to thadeus For This Useful Post:
    sidwho (15th May, 2013)
  4. #18
    May 2012
    wales
    Default sx125
    dose the resetter work
    i have alot of epson resetters so if you need any inbox me with email
  5. #19
    Top Poster gspeedy's Avatar
    Apr 2009
    MERSEYSIDE
    Will this work on SX110 or SX115 ?
    HAPPY NEW YEAR, DK MEMBERS!
  6. #20
    gmb45's Avatar
    Nov 2008
    park bench, hedge bottom, police cell
    nearly 50 thanks posts have been deleted from here, please use the thanks button located bottom right of each post, thanks posts just clog up the threads and make them harder to navigate.and please dont post any crap they will also be deleted.it is also customary and polite on any forums to make your first post here---> http://www.digital-kaos.co.uk/forums/f2/
    May 2012
    Quote Originally Posted by akramjef View Post
    dear andy91
    "connect it to out side waste ink container" where I dont understand?
  8. #22
    Canker_Canison's Avatar
    May 2010
    12th Level of Hell
    Quote Originally Posted by renooshka View Post
    On the back of the printer is a small door.
    Behind that door is a clear pipe that takes the waste ink to an absorbant pad.
    Disconnect the clear pipe from the bottom connector
    Gently pull the pipe outside of the printer
    Either extend the pipe, or find a container that can reach the pipe, so waste ink will be collected outside the printer.
    Canker
    [COLOR=Green]
  9. #23
    May 2012
    dear johnnybeast
    i'm trynig hard to download the file you 've posted but i can't do because it showing me a message that i have to wait ...or something i don't anderstand ...can you help me to download it ?? thank you much !
  10. #24
    May 2012
    i tried to download it ...but it doesn't want to get me the file ...could you help me to download it ?? thank you !
  11. #25
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    Quote Originally Posted by wahrani31jackson View Post
    dear johnnybeast
    wot part of ( i have to wait ) is the problem .. give the server time to update u as a new member, and stick around m8 . theres thousands of things on here to learn
  12. #26
    May 2012
    Default Waste Ink
    Looking for a way to reset my SX125 Printer. Tried a few programs but no luck yet ;-(
  13. #27
    May 2012
    Quote Originally Posted by jacklee View Post
    Hii, dear;
    I have an Epson SX425W printer and looking for waste ink tank resetter..If you have this can you send me.
    Great thanks for your effort in advance.
    Please send it to:
    ( no addys )
  14. #28
    May 2012
    Default sx 125
    hi i have a problem with epson sx 125. after changing cartridge there is still a notice that the ink is empty. can you please tell me which program i need to use to reset my epson. sorry for bad english... thanks!
  15. #29
    May 2010
    12th Level of Hell
    Quote Originally Posted by ivanvk View Post
    You don't need to reset the printer, you need to remove the cartridges & wipe the chips before putting them back in.
    If that don't work, take them back to the shop.
    Compatable cartridges don't always work.
    Canker
    [COLOR=Green]
  16. #30
    Jun 2012
    Hi !
    I saw that already works on SX125 and SX130.
    Does this software work on Epson Stylus SX230 ?
    Thanks in advanced.
