Page 11 of 19 FirstFirst ... 678910111213141516 ... LastLast
Results 151 to 165 of 279
  1. #151
    Canker_Canison's Avatar
    12th Level of Hell
    Quote Originally Posted by topjazz View Post
    I just bought 1 original epson cartridge (yellow), and replaced it.
    After replacing it, all cartridges are disabled.
    I must say in the past i used also compatible cartridges.
    I've tried everything (power off for a while, desconect from pc, etc...), nothing helps...
    I hope the epson sx125 waste ink counter tool will help...
    Greetings,
    topjazz
    It's a duff cartridge, go and get it changed.
    THIS SOFTWARE WILL NOT FIX CARTRIDGE PROBLEMS
    Canker
    "Animal, vegetable or mineral... I'll do anything, to anything, with anything"
    - The Baby Eating Bishop of Bath & Wells
    [COLOR=Green]
  2. #152
    Nov 2012
    Hallo,
    thanks for the answer, Canker_Canison !
    the software (epson sx125 waste ink counter tool) did not work, because all cartridges must be active.
    the yellow cartridge have i replaced with a compatible one, and it's work again
    after repacing the yellow cartridge the software (epson sx125 waste ink counter tool) works, but i have not enough knowledge to work with it (it's english, maybe there's something in dutch ?)
    Greetings,
    topjazz
  3. #153
    Nov 2012
    Do it works for stylus sx235w?
  4. #154
    Nov 2012
    Hello people! I have an Epson sx125 and i tried to reset it through an application called ssc service utility. the problem is that this application is not compatible with my model. I am running win7. Do you have an idea in order to reset my printer?
  5. #155
    Nov 2012
    Thanks for the tool.
    As told before, it won't work if there is already one cartdridge with problems/not recognized.
    I guess I'll get a black one original and then the procedure for using compatible cartdridges should work with no problems at all.
    Also, I'd probably apply for a CISS system avoiding wasting time and money with expensive (ratio ink/price) cartdridges.
  6. #156
    Dec 2012
    Default sx235
    hi does this sofware reset the sx235 printer
  7. #157
    Dec 2012
    Thx dude!
    Do you have reseter for px660?
  8. #158
    Dec 2012
    Default Do I need code for reseting the counters like wic reseter?
    do I need a code to reset the printer ink counter?
  9. #159
    Dec 2012
    i did try to take out all ink (non original)cartridges for few minutes,disconnect printer from comp and mains,and install them again.didn't work for me.now will try soft posted here
  10. #160
    Dec 2012
    Default refill
    will it work after refilling cartridge with needle by myself?
  11. #161
    Dec 2012
    Thanks. I'm going to try it.
    EDIT: I have tried it but my problem has not been solved. My problem here is that I have two new cartridges (compatible ones with auto-reseteable chip) and the printer says it doesn't recognize them (cyan and magenta). Do you know what could be happening here? I have tried different cartridges but the result is the same.
  12. #162
    Dec 2012
    I still dont understand why Epson is doing this. It is so unfair that I have to buy new blue color. I dont use blue but is is draining. I only use black..
  13. #163
    12th Level of Hell
    Quote Originally Posted by yatata View Post
    The cyan & magenta chips are faulty & need replacing.
    Canker
    [COLOR=Green]
  14. #164
    Dec 2012
    why do we need to reset the ink, they said that may pad ink end of service :t
  15. #165
    Dec 2012
    Default help me
    help me, my epson sx130 don't see black color original
