Results 1 to 10 of 10
Hybrid View
    alotmentman
    Guest
    Default how to send back up file back to dream box
    help ive got dm 500s with just green lite ..tried flashing with dream up but still no picture etc .just green light it states on computer that box success flashed ?//ive even copied a back up of a working box but need to know how to resend it back to the other dm box not working ..tried through dream up after flash but wen i open file to resend back up to box its not showing up ??yet its there wen i open file up without dream up ?is it something to do with file being a different sort please help pullin hair out thanks to one un all
    alotmentman
    Guest
    Quote Originally Posted by alotmentman View Post
    ive noticed all other file that sent to dmbox are zip file do i need to change file type ????
    DK Veteran potrobber's Avatar
    N Ireland
    have you checked scart lead is ok
    you would think if its flashed ok it should show bootup screen atleast
    have you tried a few different images open pli i find ok for dm500 never had any trouble with any pli images
    also a different version of dreamup might be worth a try
    alotmentman
    Guest
    scart lead fine mate i try different dreamups is there any other images can try different from pli jade ? thanls for reply
    Shite Link King Shady's Avatar
    Dec 2010
    192.168.1.xxx
    before you do, try using the rca outputs from dm... it may be ur scart socket on either tv or dm...
    alotmentman
    Guest
    scart ok tried other dm box on it woks fine .tried to use backup of good dm box.wots best way transferin backup from good box to other dmbox thanks
    Dec 2010
    192.168.1.xxx
    dreamup is the best way, ive had no probs using telnet tho..
    alotmentman
    Guest
    Quote Originally Posted by Shady View Post
    used dream up to save back up to computer ...saves ok but when i try to flash back to the other dmbox ie open documents find file then click onto it it dissapears off folder is / is it suppose to do that then wen i press open and let dreamp up flash box it loads file .comes up success flashed yet wen put on tv nothing there ????is the box fu;;;;;; thanks
    N Ireland
    m8 did you try this good advice yet from shady
    (before you do, try using the rca outputs from dm... it may be ur scart socket on either tv or dm..)
    dm being the one needing checked connect it using red white and yellow cables see what happens
    alotmentman
    Guest
    thanks tried with cables no different .any other suggest please
