Results 1 to 15 of 28
    Default Kia Sportage immo off 2.0 K08H M261206566
    I need goog solution for immo off in car Kia Sportage 1998year 2.0 gasoline,
    K08H FED EU
    M261206566
    BOSCH
    B58253(24C02) and B58399(29F010)
    Please help.
    This car was repaired ahead of me in vain by another person and do not know if I have the original files in the immo in ecu? I see that the memory of the ecu immo 93C46 and 24C02 were soldered. I have SBB to program the keys, but logging in immo on displays the wrong code, which I calculate the number vin. Please help
    Please help guys!
    I have read the keys with silca with a friend.
    1: FF 00 BD205900 4
    2: FF 00 BD238A00 4
    I have two immo box and one ecu but somebody solder chips so I don't know there is oryginal files.
    Jun 2009
    the memory with name 93c46_immobox1_x8 contains your keys . the password can be find via vin with sbb.
    if you cannot program again the keys with ecu i csn give you virgin file for ecu 24c02 .
    the memory 29f010 contains only the software for immo you not need to do something with it
    if you want immo off you must change the software in memory 29f010 and some changes in pcb.\
    just program again your keys
    I have immo code from sbb and from dealer Kia. Tha same number. But I can't program the keys because SBB show pin not valid and in immo shows 18 key programmed. Please give me clear dump for ecu.
    Oct 2010
    Greece
    Hi all i have same problem with same ecu....any solutions ?? immo off is possible ???
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    this is for you.../
    Regards Vasko, Bulgaria
  8. The Following 6 Users Say Thank You to vasko For This Useful Post:
    darkshiningg (12th January, 2018), gstama (23rd July, 2019), keymaker.gr (15th February, 2016), Krittanu (1st June, 2021), PierreTheron (31st August, 2023), SMARTBOY (25th February, 2016)
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    if you have immo off lpease read 29f010 and post
  10. #9
    Oct 2010
    Greece
    thanks for the help...this file is for B58253 ??
    Can you please explian in english in yout txt file
    immo off how can i help you ??
    thanks in advance Vasko
  11. #10
    IMMO off :You have to desolder eprom, program 29f010 immo off file, change position power amp driver and solder wire form old postion to new position IC.
    Vasko send you file to automatic immo learn by ecu. So you must program eprom ecu vasko files and put 2 times ignition on, do not cranking!
    If Vasko solution not work please send information than I send you my immo off solution.
  12. The Following 2 Users Say Thank You to mellon For This Useful Post:
    keymaker.gr (15th February, 2016), melina26 (28th June, 2019)
  13. #11
    Oct 2010
    Greece
    many thanks ...i will report if i use it.....
    But if you can also send your solution too...
    thanks in advance
  14. The Following User Says Thank You to keymaker.gr For This Useful Post:
  15. #12
    Quote Originally Posted by keymaker.gr View Post
    thanks in advance
    Hey Friend Files works for your car ?
  16. #13
    Quote Originally Posted by vasko View Post
    this is for you.../
    i have Kia Sportage 2001 need Immo Off
    i don't see immo off file in this Files , instruction in PL Language ,Can you write in English
    Thank You in Advance
  17. #14
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    Send me email
  18. #15
    can i have your Email and what should i have to send you
