If you use ecu safe you will be removing the ecu again in future to use proper Dpf off so get it done manually and you can forget about this car
i have only a question, i have to remove a filter dpf from this nissan qashqai, probably edc16.
i have decided to read and write only to my bdm to have zero problems...
now, not sure to the correct procedure to remove the filter...
i have to reset all error in ecu, read ecu, work file and write ecu, try the car, if no error, i put in garage to remove the filter...
now my question is: it's good my technic or is bad?
i have to remove filter or only drill whit 4 holes ?
anyone have doing this car correctly?
thx for response to my question...
Assistenza Autronica - Italia - Sardegna - Nuoro
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
i have other program, not ecusafe
Best choice in this case original dumps w/o fap with same horse power. But need to do injectors coding.
I have see the ecu, is a sid 305, not possible to read and write whit my cable....
what ecu in this car?
Sid305 siemens
KESS v2 does that ECU
