best image is a matter of opinion,
so im my opinion, the best image for a dm500 is the new commando image.
http://www.digital-kaos.co.uk/forums...elease-260519/
hi guys,
i'm looking for newest/best image, most stable, fuly patched and ready to go on dm500.
i've got cline from provider and know where to past it but apart from this i dont know anything about images that is why i'm looking for image ready to use on my dm500.
i would realy apreciate if you can help or even upload one.
thx
Like barrowside its down to opinion.
I come across this one the other day and I quite like it -
Best advice is get one working, back it up then try a couple of the others out see which suits you best.Code:http://www.digital-kaos.co.uk/forums/downloads/images/2/marwensat-2-4-maxvar-dm500s_08042012-2091/
Will this work on Dreambox 500s clone?
I got a 500s as a gift so I'm only used to the DM800's.
Does this come with cccam integrated?
I need to put image on by using a cable is that right?
Can it be done by browser?
Also are bouquets installed the same way as a DM800?
Will this work on Dreambox 500s clone?--yes
Does this come with cccam integrated?--- no you have to manual instal. (real simple though )
I need to put image on by using a cable is that right? --i flahshed with null modem cable, but i belive it can be done with telnet commands. (a bit over my head.. ) once the commando image is on though if you press menu service, there is an option for image backup/upgrade. you can use this feature to backup your old image, also if you ftp an image into your temp folder, the box will flash from it.
Can it be done by browser? ---don't know
Also are bouquets installed the same way as a DM800?-----bouquets are preinstalled
worth having a look, if you dont like it, just use the backup/upgrade image fuction to flash summit else..
use DCC dreambox control centre to FTP it over.
CCcam file goes in var/bin/emu
CCcam.config file goes in var/etc
to find the ccam controls.
1: press blue button (features menu)
2: press arrow up , highlight "extra's menu" and press select.
you will the ccam options
I have the commando image downloaded.
Do I use dreamup via null modem cable( I have a cable from an old starview cable receiver- is this a null modem cable?)
Also would cccam 2.1.14 do for this image?
Thanks and sorry for q's but am only used to DM 800's
yes , just connect the box up and see if it connects.
then you will know if you have the right cable..
Try jade 3
Which image is best for dm500C, and where to find frec in norway?
Does anyone use newcam these days?
yeah its still being used by peeps....oldskool!!
Freck
I have dream box dm500s, can commando work? What else that I need to install into 500s. I just factory re-set by accident. thnaks.
