Results 1 to 7 of 7
    swingman26's Avatar
    france 26
    Default golf mk6 ecu soft coding help
    I need help about soft coding of ecu for golf 2009my mk6 2.0 tdi.
    Need soft coding capabilities. I have a problem with my cruise control.
    Who have codes for coding please ?
    use vag com for the coding!!!
    You need to adjust the measuring blocks in 01 engine to enable the cruise, in addition the steering wheel control module also needs to be compatible of it wont work
    Jan 2016
    yes freind
    use vcds
    the acces is 12233
    I guess he solved during this 3.9 years.
    Thanks anyway.
    Mar 2017
    user vcds dood thanks
    Jan 2022
    Use Vasay!
