I've reinstalled the soft 1.14 (and tried 1.2) from Windows XP to Windows 10, but the soft can't see the programmer. The correct driver was installed in the OS. Any ideas? How did you make it work in Win10?
PROBLEM SOLVED: >>>>>>>>>>>>> https://www.youtube.com/watch?v=qxbhTMHl000
Thanks!
A
I red my AT45DB161E (U10) with tl866 as AT45DB161D with Page528 and Page512 there are difrences in both files. I did not connect 60p capacitor as sugested. Could someone read and post dump here so i can compare?
Thank you.
Col19 (18th September, 2021)
Why I can't download this software? I got a message "You are not logged in or you do not have permission to access this page."
if you had read the rules which obviously you havnt you would know.
brend (19th January, 2020), dashradio (8th December, 2018), rtbdiagnostic (9th December, 2018), teerak2uk (8th December, 2018)
Maybe someone will need ...
Useful links.
h3adroom (27th September, 2021)
Obrigado pelo up.
i have problems to generete new key to my E90 BMW
I have the R270+ Programmer ( HW 1.14 )
Software is the 1.20
I becom allways the Error
UnKnown 9s12 ID!
Maybe is 912 MCU
My process to read the MCU :I select the MCU (here CAS2_2K79X) then go to read The programmer beeps two three times on the screen PLEASE WAIT in red and green then the error comes.
I have already changed the computer. Once Win10, once Win7 - no change yourself errors. To be on the safe side,
I soldered the cables again. No change either. I hope someone can help here?
Greetings DarkSnoop
You did mistake like me first time, look picture again. You should connect not 9 but 19 is correct then it's gonna be good. and not 5 only 10. yesterday connect this cas2
Hi and thank you
The Wire 19 is by me OK ,
but now i must change the Wire 5
I have on the backside the Wire 5 i will take 10 , then the problem is gone ?
I will report Thank you !
Greets
Now it works i can read mcu i change teh Wire 5 to 10 !!
How i must go now i have the AK 90 reader for key coding
have anyone the right how to for coding new key for the E90 ?
Greetings
good i will make test
Hello colleagues, I was reading the whole thread and I already know how to make modifications according to the thread ... I am about to buy my R270 in aliexpres, does anyone recommend a buyer? I have 1 questions what difference there in 1.30 to 1.20?
Also if you can pass me the software since the one at the beginning does not work for me
Thank you
:wink
Anybody got it working on Windows 10?
