Same here.I believe the read you performed on the car isn't correct.
Hi im having a problem removing the dpf from this file, ive done loads of these 307hdi 2.0 ecus without a problem
Now this one just wont go through ecusafe, doesnt say dpf removed or let me save binary.
ive read the file numerous times, but its the same.
Can anybody try on their ecu safe?
many thanks
Car Diagnostics
yes, its read via a kwp2000 flasher in fast mode..
im gonna try in slow mode next time
the ecu is h/w is 0281010747
Car Diagnostics
Hi! Is the KWP2000 reads the whole dump or maps only? It would be the best use eprom reader to have complete dump.
Your dump is ok, ecusafe not correct this ecu.
Dpf off file here
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
is there a dpf fitted to the car?
check on a ramp
"I always tell the truth. Even when I lie"
"We Taking Over, One City At A Time"
0281010747 is for 307 2.0l hdi RHY ( 90 hp ), no dpf in this car
