Results 1 to 15 of 16
    Mar 2011
    Default Trouble with DM500S
    Hi guys having trouble with my box..its been working fine for over a year no problems..the last week i havent been able to poick up my premium channels i still recieve FTA channels...i can connect the box to the internet i have checked that..i got a no ip address a 2 weeks ago but im not sure if i used since then?also when looking at the CAM.CFG i noticed there was a folder above say NO.corefiles(0) with nothing it..it might have always been there but i have never seen it..so i dont know what is wrong but im sure at least one of you legends of kaos will have a idea cheers
    DK Veteran Rodbouy's Avatar
    looking /var/etc/CCcam.cfg
    also check with who you get the specials from as i take it they are not your own.
    Mar 2011
    yep they are fine as i have requested new lines(i know they are legit as i have had them for 4 months+)..and they dont work either..in my cam.cfg file there is only that cline..should there be any other text?(there is a line above saying connections?)
    Is that file "no.corefiles" supposed to be there then i take it?
    Quote Originally Posted by Grimbo84 View Post
    download cccam pppanel and see if they are connected.
    Also got softcam setupand save and restart cam
    Mar 2011
    thanks for your help where download that from?
    try the download form the box.
    Its in the pli download section.
    Prob be varients depending on what img your running.
    Mar 2011
    ok m8 i have downloaded that how do i access it?
    yellow button for plugins
    Mar 2011
    ok m8 done that went into servers.. it has the cline in there.. there is a blank space below the bit that says connected if you know what i mean?
    If it says connected then its possibly ure end, did you save and restart cam ?
    Mar 2011
    yes i saved and restarted cam.
    what else co i do?all that should be in the cam.cfg file is the cline right?
    also in network both boxes have to be ticked(DHCP)
    Your network is fine or it wouldnt have let you download the ppanel.
    lines in CCcam.cfg located in /var/etc
    Give them to a mate to test and see
  13. #13
    Mar 2011
    yes checked this morning lines working..anything else to check?
  14. #14
    So they work in mates and not in yours?
    Only thing left if factory reset and start from scratch?
  15. #15
    Mar 2011
    so would i have to flash my box?i got my box already flashed..i wouldnt know what i would need etc?its strange that it worked fine only a few weeks ago?
