I can confirm that rumour. It didn't work for me either with 2011/3 - 30250.
Regards,
Smac_a
Regards,
Smac_a
English Please
Ever thought of joining the Emergency Services, with your responcse time?
ON TOPIC:-
ELCHIP:-
That programme to change the serial number as required, can you share it, if not:-
Who ever that file that changes serial to 32050, what is it made with, can it be edited?
Meat.
yes. 30250 doesn't work with trucks =)))
It's working, tested(man - engine TGA) and unlimites licensed.
Good luck!
I have Autocom Car (30250) and trucks (39071) and have tried following:
- Change the serial 39071 with SN30250 (the exe runs but does not leave any message, on win7) on the trucks and install hardware activation with a-710-254, GFOBCJMBUQHY. Result, configuration window still appears SN39071 "the activation is not the same of the hardware".
- I tried install the software for trucks with SN 30250, a-710-254, GFOBCJMBUQHY and hardware for use with cars. Result, "the licence is activated is not the same of the hardware".
Can anyone give some idea on how to use two hardwares for use it for cars and trucks?
Thanks in advance.
What serial did you change (interface or installation)?
Change the serial from one interface to the other number (30250 to 39071 or vice versa) and install cars and truck both with this (the same) serial. Installation serial has to match to the interface serial.
Or use different partitions on computer.
Or try to make vmware installations.
Be sure your cars interface has right capacitors for usage on trucks.
Instalation on diferent partition and wmware is unless.Need to have the same serial on hardware and on the instalation.
Some cuestions:
- It's possible to use the same DVD 2011.3 instalation for cars and trucks with diferent serial numbers?
- SN30250.exe it's working well? I execute with win7 64Bits and don't appear anything on screen, only port number if it's not correct in .ini
- This SN30250 change any SN to 30250 or it's made to change it to another SN?
thanks!
The installation dvd is the same for trucks and cars. But you can't install it together for different serials in one os. That's why i told you to use different partitions (multiboot system). You can also try to make two vmware installations (one with 30250, one with 39071). Of course you have to use that interface that matches the installation serial.
For changing serial in interface there are some tools here at dk.
Wrong you can install Truck with 39071 and Cars with 30250 . But you cant install Cars or Trucks with 39071 and 30250 . This tools have a lot of possibility i use in same time 2008 2009 2010 2011 Cars in one computer .
If you try to change serial , after change read the serial to see if its OK . A good freeware for that is RealTerm .
All serial work if you are offline or block main.exe .
I dont know why all people use 30250 there are a lot of serial, and keymaker is easy to find with Google .
Autocom TEXA
Toughbook CF19 MK1 ssd 64gb ram 4go Windows Seven Professionnal
I understand not all what you are saying, sorry, maybe you can explain it?
Afaik you can install cars or trucks software with any serial number you like, as long as you have matching setup information (id and hw-key). You can use 30250 for cars and trucks, you can also use 39071 for cars and trucks, but i think you cannot use 30250 for cars and 39071 for trucks on same partition/windows installation (iirc that causes trouble with activation for 2011.3). Maybe i'm wrong or i missunderstood you.
