line 9-RTC-real time clock .
hey you have to change the Software 32 bit memory Card
this problem happen when the software damage .
sarigol45 (17th August, 2016)
anyone know if I can do a ecu flash with a tech 2 clone or if it is safe to connect to the internet a gm tech 2 clone
Hi aglinsky how you solve that problem? please tell me i have same problem.
thank you.
I have problem, but my tech2 not start to screen checking the system, only view lines in the screen after that i have 3 sound equals. With memory 32mb put on or not, its same problem.
Any have or listen this problem???
PD: sorry for my bad english
009 is not rtc, when rtc fail change internal battery. 009 is clkmem
I had RTC fail but changed the battery. Now I have CLKMEM problem. I have been told just to set the clock but I cannot pass the blue POST screen to change the clock.
Any ideas please?
I had rtc fail and clkmem fail, after i adjusted the clock, also damaged my tech2 suzuki bin file on the 32mb card, see here(https://www.digital-kaos.co.uk/forum...Tech2-card-bin),
the 32mb card is ok but the data is lost
Fixed the problem with a gm card,where in the menu you have system check, i used that option and clkmem was fixed
about the rtc fail, just ignore it, or put year 2000 and it will become a pass
I'm still looking for a suzuki .bin file though!
