Cheers again Highlander, really appreciate it considering how busy you are, you should have left it a week until tps have settled more they'll probably change again, but I don't want to sound ungreatful
Hillsborough 15th of April 198996
Thanks very much, been using this list for some time now like the way it's set out![]()
hi happy highlander thanks for all your hard work, i was just thinking, would it be easier to just change frequencies of certain channels instead of replacing your whole channel list as iv got mine as i like it, is there any chance you could tell us the new frequencies please, id be very greatfull, thanks in advance
if you want frequencies you'll find them herehttp://en.kingofsat.net/
As Above from HH post and Zee24 if any member is looking for change of frequency or even a newly added transponder then please visit anyone of the 3 most popular sites to keep up to date, I have listed each link to go directly to 28.2? east but as usual thses sites list all available satellites if needed:
Flysat : FlySat Eutelsat 28A - Astra 1N/2A/2F @ 28.5/28.2? East
Kingofsat : Astra 1N / Astra 2A / Astra 2D / Astra 2F / Eutelsat 28A / Eutelsat 28B (28.2?E) - All transmissions - frequencies - KingOfSat
Lyngsat : Eutelsat 28A & Astra 1N/2A/2F at 28.2?E - LyngSat
And just to add these are not to be taken as Gospel that they are absolutely spot on, As with any site these 3 rely on General Satellite enthusiasts reporting changes on a daily basis which means that one site maybe more up to date with changes than any other so it would be wise to check on all 3 to make sure.
happy_highlander (7th October, 2013), zee24 (7th October, 2013)
Another quick upload with the new channel put into favorites but not in order. There are quite a few channels now running on two frequencies so I have added both to favorites and as I've no idea when they will switch one or both off and change it again. At this stage I'm just putting channels on as they appear and removing them as they disappear as best I can. Once everything settles down I'll upload new lists all back into order........I have not been adding or removing any box office channels but will sort all these out when they are finished p1ssing around
zee24 (8th October, 2013)
Thanks to happy_highlander for his list as I used that as the basis for this one![]()
tony_i (9th October, 2013)
happy_highlander (9th October, 2013)
If you want to keep an updated irish variation by all means do so. Just start a thread titled as an irish variation of my list m8. I upload the lists to be used but do spend a lot of time on them, not just these ones but also the enigma lists and multi sat lists so would appreciate if anyone is uploading a regional variation it does state that it is just that a regional variation of my lists. A quick do you mind before the act wouldn't go amiss either.![]()
