Results 1 to 7 of 7
    Bulgaria
    Default Clio 2 remote rf key lose synhronisation
    Hello. I have Clio 2 in my garage with problem of lose synchronisation between remote control and central locking module after turn ignition key on MAR.
    After synchronisation procedure with CLIP, remote key working good. Lock/unlock without problems. But when i turn key on MAR(ignition) ant then off remote not work.
    Where is the problem?
    electrones's Avatar
    Feb 2012
    Around C.V
    Hi friend
    I think you have anything to interfere with the RF polled sent to the module. But check the connectors on the module central locking / alarm if it's ok, and your antenna. if ok check bataria the remote control and internal circuitry of the remote are ok.
    good luck, I hope that your key is the type KRS + RF to not have problem with the immo.
    Bulgaria
    The car is with immo off solution after bad starter motor repair in another garage. They burn the old ecu and uch. I remove immo and cut steadily +12v line to ecu. But i think that is not the problem. I will change battery in key and try again. Now car start ok and work ok and problem is only with central locking.
    Interestingly, when i synchronize remote i can unlock the car and lock it many times. Only when i put the key in the position on IGNITION (without start the engine), then the remote stops working. This is very strange for me and i don't know why is that.
    EDIT: maybe problem is in immo? When immo not recognized code from key maybe he reject remote from the memory... if is that, i must learn key to immo.
    I do not have a solution but..
    I have had the same problem when trying to program used keys with various eeprom dumps. So I suspect the fault is in the dump in the bmt unit in 93c46.
    A Renault XR25 programer would prob sort it but tend to be dealer only tools. Zedbull with the renault eeprom package ( special renault remote function ) will aslo sort it.
    Good luck
    Bulgaria
    Please, calculate PIN from dump.
    BCM is SAGEM
    Apr 2011
    Romania
    Quote Originally Posted by oem View Post
    BCM is SAGEM
    pin : 4271
    Bulgaria
    I solved problem after disconnect and reconnect BCM Maybe problem is in pin contact. I only disconnect from car read dump from memory and reconnect and now remote working
