Results 1 to 10 of 10
    Apr 2012
    Default hard drive for vu
    after deciding to buy a vu duo( not ordered yet) i was looking for some hard drive to fit in and found one laying around a external freecom 400gb. i open the casing to see the specs:
    400GB/7200rpm/8M/PATA.
    i assuming that this one is not good right?
    DK Veteran Rodbouy's Avatar
    Any 3.5" sata will fit it mate.
    Apr 2012
    but the one i have is 3.5" pata
    no you need a sata pata doesnt wor. Not unless there is a converter.
    Apr 2012
    ok i was afraid it wouldn't work
    V.I.P. Member dell_xps's Avatar
    SATA you need m8, or get a converter from ide to sata on the bay, or just use it as an external drive with your VU, easy.
    Apr 2012
    due to short on funds, does the converter works well with the box or i need a sata hard drive. i'm not a fan of external and it will look ugly and missus would kill me.
    Sure someone on here posted they were using one m8, do a search !
    Apr 2012
    Took the plunge and order one ysterday.
    Regarding epg and picons is the any big diference using usb stick or hard drive? I have harddrive to fit do i realy need to use the usb stick or the hd will do the job. There is nothing left on pig bank
    I use a hard drive for picons/epg/vfd etc etc, a lot of peeps use a usb stick, probably quicker using a usb stick, but if yer not bothered, stick them on the hard drive if funds are tight.
