Results 1 to 13 of 13
    Mar 2011
    Default Volvo Cable for Euro Trucks
    Attached is a picture of a truck from Spain. A customer wants to connect the Volvo Adapter and use PTT.
    Does anyone know what cable I need to purchase to get this customer going? Thank you.
    DK Veteran dimitar22's Avatar
    Jan 2009
    you need OBD 2
    cable
    Mar 2011
    Quote Originally Posted by dimitar22 View Post
    you need OBD 2
    cable
    I didn't realize they use OBDII in Euro on big trucks ... Thanks!
    Apr 2010
    Which model?
    FL?
    Mar 2011
    renault dxi & volvo fh
  6. The Following User Says Thank You to drizzt4321 For This Useful Post:
    5189shura (3rd September, 2013)
  7. #6
    Jul 2010
    for Adapter 88890020 cable 88890026
    Renault dxi EOBD
    1. +APC fil 22
    2.Non utilise
    3.Non utilise
    4.Masse fil 1
    5.Masse fil 1
    6.J1939 Engine+ fil 0462
    7.KWP2000 fil 851
    8.KWP AC fil 041
    9.Non utilise
    10.Non utilise
    11.Non utilise
    12.J1587+ fil 0010
    13.J1587- fil 0011
    14.J1939 Engine- fil 0463
    15.Non utilise
    16.+APIG fil 452
  8. #7
    vuno01's Avatar
    Jun 2010
    Europe
    i think cable must be especific for trucks
    because they use 24volts not 12
  9. #8
    Jul 2010
    88890020 Adapter works for trucks 24volts for vans
    12 volts
    Volvo 88890027 8 Pin Cablecable
    Renault 88890026 16 Pin Cablecable
  10. #9
    May 2010
    NL
    Hi have somebody succes to connect an Autocom Trucks with 8 pin or 16 pin renault DXI ?? I tray 4 autocom nothing.
    i Think we need an extra special cable the same as
    for the Texa see picture Sorry I dont how I can do it
    i means send the picture from the Texa Adapter
    Regards T
  11. #10
    Member riggerout's Avatar
    Sep 2010
  12. #11
    Dec 2010
    Quote Originally Posted by pencho View Post
    Renault dxi EOBD
    1. +APC fil 22
    2.Non utilise
    3.Non utilise
    4.Masse fil 1
    5.Masse fil 1
    7.KWP2000 fil 851
    8.KWP AC fil 041
    9.Non utilise
    10.Non utilise
    11.Non utilise
    12.J1587+ fil 0010
    13.J1587- fil 0011
    15.Non utilise
    16.+APIG fil 452
    as would be the connection to usb Nexiq; to OBD2?
  13. #12
    Feb 2010
    Quote Originally Posted by drizzt4321 View Post
    ptt***65311;
    which hardware you use?
    nexiq?
    88890020?
    or 9998555?
  14. #13
    Nov 2010
    Default cable
    h..p://www.digiobd.com/index.php?main_page=product_info&cPath=10&products _id=111
    didnt want to post direct link as not sure of mods approval, you may look there, put tt where the dots are, I am not a seller, I bought from them , ask for owen, he helped me and there hardware is good.
    here is another that makes also for nexiq to european
    h..p://www.trucktest.ru/nexiq_eng.htm
    Cable for connection between communication unit and the vehicle communication outlet. OBD-connector Volvo BUS B12 ( 9998960) Price 65 Euro
    Cable for connection between communication unit and the vehicle communication outlet. OBD-connector Volvo FE ***1080; FL,Renault DXI.(88890018) Price 65 Euro
