Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    Nov 2008
    use post 6 firmware
    mine is ok using this
  2. #17
    Oct 2012
    yep tried that and i still get the breakage in sound, its no different.
    if i turn the box off then back on its fine but after a while it will start again.
    i have now tried 6-7 different FW and still no change so im presuming its my box
  3. #18
    Aug 2012
    Quote Originally Posted by markedz View Post
    use post 6 firmware
    Anyone know if i can use this with a skybox f3, been having the same issues with sync
  4. #19
    Oct 2012
    Northern Ireland
    Quote Originally Posted by colpac View Post
    Sync faults could be down to your server-clines or router. Not always the box itself.
    If you remove the cline and scan on FTA only do you get sync probs?
  5. #20
    Aug 2012
    Yes the problem is on FTA as well, starts off ok then after 10-15mins its gone out of sync, have had several different servers with no change so different firmware is worth a try
  6. #21
    Dec 2012
    Can anyone confirm if this will work on my F3. I am running it via HDMI through a Sony STR DN-1000 amp. After watching for a short while the audio goes out of sync. It is cracking me up. Any help will be very much appreciated.
