Post original file
Post original file
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
this is file ori.
thank
Not sure about the PPD ecu, But on the bosch ecus it is stored in the eeprom. Maybe read eeprom aswell then lower the speed limit with VCDS and read both flash and eeprom again to compare.
Hint: It is in the flash.
The speed limiter is 4C5E4 and next (210 km / h).
Test and comments.
Greetings.
Thank you. i'll test and comment
These values are those that change the EcuSafe and does not work.
Regards.
As I continue with a laps with limiting speed and can not find any info.Does anyone know anything about this?
