Results 1 to 8 of 8
    titoun's Avatar
    Dec 2010
    Default How to work autocom 1-2011 VCI with 3-2011 release ???
    Hi all, Is it possible to run an interface AUTOCOM 2-2011 with 3-2011 software release??
    and if so how:
    Should we have a specific serial number (30250)?
    Another issue in the firmware component AM29F800B it is only upgradable by software??
    Thank you in advance for your answers.
    Regards.
    yes you can run interface autocom 2011/1 with 3-2011. You make upgrade in program
    titoun's Avatar
    Dec 2010
    Quote Originally Posted by michalez View Post
    Hi, thank for your respond.
    You just need to upgrade the firmware after you install version 3-2011?? is that correct? Then I activate the software with keygen and it works?
    I have 1-2011 version to install on my PC ! Is it to remove it, before installing the 3-2011 version ?
    Regards.
    DK Veteran chrismoore02's Avatar
    Jul 2011
    England
    yes once you are running 2011.3 you will need to update the firmware on the interface from within the software
    Jan 2012
    Remenber to do it with power supply for that (12v)
    Enviado desde mi GT-I9100 usando Tapatalk 2
    May 2011
    Quote Originally Posted by titoun View Post
    and if so how:
    Regards.
    the 2011.01 hardware can't run 2011.03 software.....
    all the version can't update right now
    Jul 2011
    England
    Hmmm my 2011.1 hardware is running ok with 2011.3
    Aug 2009
    It's working, but need to make firmware update.This firmware update from 2011.3 take 10minute and 1 tigarete to smoke.
