Results 1 to 5 of 5
    Default Mercedes SKC alculator, some questions.
    Some questions about this calculator made by SKC:
    a. The key output format for .011 keys is grayed and not selectable. So, is it possible to calculate old big motorola key?
    b. I noticed that some keys, even with good eeprom dump without hash errors, are not calculated. Is that normal?
    Best Regards
    Mar 2009
    a) It depends on the EZS you are trying to generate keys for. If it is a newer one then it will not take old motorola keys.
    b) Its normal. Usually only a couple of keys are missing, but once I had only 3 keys generated.
    Quote Originally Posted by madaxe View Post
    About a), I want to create keys for W202 EZS for example but .011 format output still remains gray and not selectable. So I can't create big motorola keys.
    One more question: About used keys. Let's suppose that someone had lost key0. The calculator creates the key0 and names it as used. Is that file OK to create a key or the used keys are not usable anymore?
    Best Regards
    smayer's Avatar
    Jan 2012
    a) you Can convert dump format to match your key
    b) used Keys can't BE used anymore, unless you know how to modifi EZS dump
    May 2012
    Hi All, I have used the SKC generated files on .051 many times on the old Motronic keys. It works fine. Also the used keys is fine provided the key track was not manually disabled on the EIS by diags. system before.
