Results 1 to 14 of 14
    gmb45's Avatar
    Nov 2008
    park bench, hedge bottom, police cell
    Default citroen ax spree 1997 alternator problem
    ok my alternator is playing up, what i want to know is what other car can i rob one off from the scrappers, spares place wants ?60 + vat for a re-con ~~~~ that, cars not worth it, going any way this summer, what about the little pugs etc, and the saxo ? my alternator pushes 13 volt when its running right rac man tested it and said its dodgy ( goes down to 11 volts when not running right ) im not sure what ampage it is, cheers
    serious replys only please or i will ~~~~ them in the cut
    Shite Link King Shady's Avatar
    Dec 2010
    192.168.1.xxx
    dont know if any good cos i dont know shit about cars.. well i know a bit.. but not in garage sections league.anyway, im trying to help so ~~~~ you if its wrong
    Citroen AX 1.1 F Reg Alternator | eBay
    CITROEN AX 1.0 ALTERNATOR 1996 PLUS MANY MORE AVAILABLE | eBay
    Dec 2010
    192.168.1.xxx
    also give these a go, they give ur info to a load of scrappies, scrappies email u , u choose best price innit
    Car Parts | Used Car Parts & Engines | Car Breakers & Gearboxes | Electrical
    gmb45's Avatar
    Nov 2008
    Quote Originally Posted by Shady View Post
    yeh sound but need to get one from scrapper m8 so need to know alternative cars incase scrapper not got ax in.
    Meat-Head's Avatar
    Quote Originally Posted by gmb45 View Post
    Whoa, that's a bit like saying, my TV works fine when it's turned on, but when i turn my TV off Mr Branson turns off the entire network.
    That ON FACE VALUE would be your battery is shagged and your dynamo is struggling to charge.
    Suggest you go to 'Dik Motors'
    1) Disconnect the battery, put on charger overnight
    2) Does the battery warning light come on and off - ign on - on
    starts - goes out?
    3) RIP the caps off the top of the cells and use a PROPER
    'cattle prod' load tester - see what it dips to - limit is 9 volts
    check there are no gassing cells.
    4) Not sure if internal fan or not on alternator, can you push fan of alternator around with your fingers? - belt too loose.
    5) Before you charge battery - MAKE SURE YOUR AT HOME -
    or 'Dik Motors' - incase your battery goes dead.
    Turn all lights on, heater, etc etc, leave engine to idle for 5 mins
    this will drag battery well down, then GIVE IT A BOOT full 3000 RPM
    see if you get a wicked SCREEECCHHH noise from the dynamo belt
    (LOVE doing that)
    6) Chances are it's your smegulator - NEW PARIS RHONE 12V REGULATOR FOR RENAULT VERG1006 | eBay
    BEFORE DOWNLOADING SMEGULATOR YOU NEED TO
    A) check if single terminal or twin terminal
    B) get the old one off the car first and check the slip ring
    and brushes.
    HTDH
    Meat
    gmb45's Avatar
    Nov 2008
    Quote Originally Posted by Meat-Head View Post
    starts - goes out?
    (LOVE doing that)
    and brushes.
    HTDH
    Meat
    battery brand new, alternator belt brand new, just want to know what other cars i can get an alternator off thats all really.
    Meat-Head's Avatar
    Ah you didn't say it was a new battery.
    A NEW belt need to be tighen up after 100 Posts - end of the week
    but in your case as top shite poster, 250 posts time - tighten new belt
    Liteace's Avatar
    Mar 2009
    On a rock
    If the AX is an 1.100 its the same as:
    Citroen C15 1.1 - 1.4 (87-96)
    Pug 205 1.0 - 1.1 - 1.3 - 1.4 (87-90)
    Pug 309 1.1 - 1.4 (90-93)
    Volvo 740 2.3 (85-88)
    gmb45's Avatar
    Nov 2008
    Quote Originally Posted by Liteace View Post
    its a 1.0 m8
    Liteace's Avatar
    Mar 2009
    On a rock
    its a 1.0 m8
    Its the same alternator as the 1.1,
  11. #11
    gmb45's Avatar
    Nov 2008
    cheers mucker thats what i need to know gives me more options to get one get off to scrapper soon, just need nother dump first
    gmb45's Avatar
    Nov 2008
    a was going to get one from the auto spares place yesterday but they want ?60 odd + vat ~~~~ that, ( and he couldnt be sure if the 1 he had in was for my car ) while i was there was talking to a bloke with same problem, he had 2 alternators off the same spares place, 1 didnt work ( aa man tested it and said it was ~~~~ed ) and 1 that didnt fit, his was for a seat ?130 , so that put be off the spares place. cheap shite being used to re-con them. might as well take the same risk from the scrapper at less than half price.
    gmb45's Avatar
    Nov 2008
    sorted, couldnt get one from scrapper, was just about to fetch one from auto place for ?74 then thought hmmmmm go n see dik its on me way, he put me one to another scrapper that had one, put on at diks, dik tested it and its ok and only cost me 20 beer tokens happy days cheers all for the replys
    Meat-Head's Avatar
    Dik, mate, ring that pther scrap yard, call them *****'s.
    1) Price was too cheap
    2) They should have took ?20 + VAT & his Shitreon off him
    3) Can you do a post mortenm on the old dynamo - 2 screws,, bolts torx or whatever they had to hand.
    or just smash the reg off.
