Results 1 to 7 of 7
    Mar 2009
    Default streaming movies
    is it possible to stream movies from the pc to et 9200?
    digicon's Avatar
    Quote Originally Posted by blueflash234 View Post
    Yes it is possible just create a network mount on your box and PC and share from there
    Gods Country - Liverpool
    Yes, and it is very easy to setup. If you are using a linux os, you can make your pc into a DLNA device, and the ET9000 will pick it up and play media direct from it.
    Mar 2009
    how do you make your computer a dlna device and how does the box pick it up?
    Not sure how to do it on Windows, but on Ubunti there is software that you install, and it makes your pc broadcast on the dlna network.
    digicon's Avatar
    Unsure what Image you have on your 9200 so, But it should have an option for you to create a Cifs mount folder on your PC/Laptop etc.. which will allow your 9200 to see this on your network. Anything you want to watch put in that folder and away you go
    Mar 2009
    the image is xtrend v4
