Results 1 to 11 of 11
Hybrid View
    Default ecu program OPEL CORSA with OP-COM
    Hi,i have to change opel corsa 1,7 dti ecu 09389429 .
    I have buy an other,already programmed with my car infos:
    Car Reg&Chassis number
    Make/Model of Car
    Has the car got ABS
    Brakes
    Has the car got Aircon
    Has the car got Traction control
    Has the
    car got Cruise Control
    Is the car an Auto or Manual transmission
    Does the
    car have a standard Vaux Alarm fitted ?
    Now i have to fit in car and program with the immobilizer with op-com.
    It's my first time,could you explain me the right procedure,please
    Italy
    Hi, if you have carpass you can go to engine page with opcom than reset ecu. After on the immobilizer page select programming function, insert the pin code and you can find the command to sincronize immo with the engine ecu. Bye!
    Aug 2011
    Spalding
    Hello
    Edited as Im too slow again.
    Martin
    QUOTE=marcoco;1550060]Hi,i have to change opel corsa 1,7 dti ecu 09389429 .
    Make/Model of Car
    Has the car got ABS
    Brakes
    Has the
    Does the
    It's my first time,could you explain me the right procedure,please[/QUOTE]
    Dec 2010
    I always use orv commander to know the pin code and reset any used ecu . orv work very well for opel
  5. The Following User Says Thank You to kar407 For This Useful Post:
    salahmanu (27th May, 2013)
    Aug 2011
    Spalding
    Hi Kar407
    Can you recommend a good supplier for the orv commander?
    Martin
    Quote Originally Posted by kar407 View Post
    May 2012
    ecu pin reader
    SMOK
    Jun 2012
    Thanks you
    Jun 2012
    Default Thank you
  10. #9
    Member schumy1502's Avatar
    Romania
    search the garage end you wil find the how to match ECU
  11. #10
    Multipla's Avatar
    Turin,Italia
    An the ept for program smoke wath is?
  12. #11
    daniersms's Avatar
    South Africa
    Opcom works well the trick is that you must know the pin for the immo and the pin for the ecu to reset them both.Small things like security wait time can catch you out if you dont look out.T300 can read immo pin from immo and you can read and post dump from 25C320 in ECU to get pin for ECU
    Love this forum
