Page 5 of 5 FirstFirst 12345
Results 61 to 65 of 65
  1. #61
    Jan 2024
    Good day!
    Can anyone help me with a bmw key mechanical code and corresponding cut sequence for this cas3 dump please.
    bmw e70 2011 X4XZW41110L829343 if necessary
  2. #62
    Sep 2010
    key cutting code HA00035857.
    CUT KEY 21244313 CHECK THIS ?
  3. The Following User Says Thank You to triak88 For This Useful Post:
    dguarev (24th January, 2024)
  4. #63
    Jan 2024
    many thanks for cutting code
    a couple of minutes ago installed Instacode. it gives the same cut sequence.
    thanks again.
    could you tell what program did you use to read eeprom? just for self-development...
  5. #64
    Sep 2010
    I read with VVDI2.
  6. #65
    Jan 2024
    I analysed the data from thу current thread (eeproms and key with corresponding mechanical codes) and found out that key mechanical code is represented by four 16bit words at address 00000B39 in CAS EEPOM
  7. The Following User Says Thank You to dguarev For This Useful Post:
    wuza (15th February, 2024)
