Hello
I have the same unit delphi.
but I need to connect to read the micro st10f280-b3 (991de) of ecu delphi
the switchboard is a Renault kangoo 1500 dci year 2007
the switchboard is delphi ref: 8200513076 - 8200582518
have tried to load cartography in the flash of the micro for obd and have blocked the ecu.
this ecu stores and save the flash and the eeprom in the micro
I have No car, so I can not do so by OBD and I need to load a new cartography through the micro.
the micro is not motorolla but ST reference: st10f280-b3 and mask 991de
in the micro can read the flash and the eeprom with programmer xprog - m
to make sure the connections and pinear in the right place and not annoy the micro. I've taken the micro data sheet and it does not coincide me.
as you've connected to read this micro and be able to read with the programmer xprog-m and make sure that forms the connections?
I hope your help
many thanks
