    Dec 2010
    Default Peugeot 307 egr off
    hello
    I need only EGR OFF for peugeot 307 1.6 hdi 110PS ecu edc16c34
    0281011629
    1039908537
    THANKS
    May 2012
    Try and raport. CS ok.
    Dec 2010
    OK THANKS
    JUST I try to modif with ecusafe2 but the soft delete EGR only if DPF and EGR is select , so i don't know if the EGR map is the only change(enginer no fap(9HY).
    My dump modified with ecusaf:
    Apr 2012
    Wonderland
    Quote Originally Posted by doudou241 View Post
    OK THANKS
    there's no egr mod in your file, only dpf...and made partially also...
    chks is not correct
    ProTuner since 1999
    Apr 2012
    Wonderland
    here your egr off
    pass in pm
    ProTuner since 1999
    inyxon's Avatar
    Spain
    Quote Originally Posted by atomiczen View Post
    here your egr off
    pass in pm
    Hi Atomiczen...It?s a tested solution? Pls send me pass or I?ll send you (or post here) same file.
    Thanks!
