Results 1 to 8 of 8
    Mar 2009
    Default help v0+clone dont boot anymore
    i had try to update my vo+clone to version 2 whit my omoddelcabel i try from winxp to update the update start fine
    put i stant still for about 2% of the update an nothing
    more happing it dont finish the update now the v0+clone
    dont start anymore it just show starting in the display and nothing happings is the a way to flash i back with the omoddelcabel
    thanks jj
    V.I.P. Member benny/9's Avatar
    Nov 2008
    north west uk
    Quote Originally Posted by jj2 View Post
    thanks jj
    have a look at the attachment and do that way
    Please Read Carefully!
    No Sky UK NDS Videoguard Hacking Discussions.
    Viewing Pay TV without a valid subscription is illegal
    the files available are kept for experimental & educational purpose only
    original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,
    Mar 2009
    big thanks benny/9
    but after many try its udate 100% but now when i put power on i can hear the vo+ run but there i only a little red light
    in the display and nothing happing i thinks my clone vo+
    is broke
    Nov 2008
    north west uk
    big thanks benny/9
    is broke
    if your sure you have updated the box with the rs232 board
    and the null modem cable, then put a image on a usb stick
    and see if you can now flash the box first tu rn the box off
    with the switch on the back panel, then put the stick in the
    front usb port and turn the box back on and it should say reading usb
    on the box lcd screen leave it to flash the box just follow the info/instructions etc;
    on the lcd screen on the box untill it says remove usb and re boot
    then remove the usb and turn the box off and give it a few seconds
    and turn on again then the box should be flashed and ready to set up
    Mar 2009
    i thanks for you big help benny/9
    but nothing happing when i turn power on there is only a
    red light in display and nothing happing
    V.I.P. Member mdt's Avatar
    Feb 2009
    bolton, north-west. uk
    why did you do the ic update if your box is a version2 as it already has the update pre-installed at the factory,regards mdt
    DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W
    Mar 2009
    no is was a version 1 but i think the botfil is gone or maybe i all broken is there not a way to flash it back to factory version
    jj
    Nov 2008
    north west uk
    jj
    first mate did you use the duo_scret file when
    you updated the box? with the null modem cable
    if not i have added it to do the update again
    if you want to try the official vu firmware
    you can find it here:-- Archive of Vu+
    make sure you use the file for your model
