DM500S Gemini 4.7 CCAM2.3.0
Results 1 to 8 of 8
    Jul 2011
    Unhappy DM500S Gemini 4.7 CCAM2.3.0
    I have just flashed my dreambox DM500S with Gemini 4.7 and tried to add CCCCAM2.3.0 and when I install reports installed correctly then I cannot load the addon, also a var.tar.gz file is created in /tmp I have tried several times. Can anyone plaese help
    Where do I find the correct cccam2.3.0 or is there a later?
    I even tried factory resetting no luck
    May 2012
    Is there a cccam.cfg in your var/etc folder.
    If not then try and extract the .gz on your pc to see if it's corrupted
    Jul 2011
    Hi thanks, there is a cccam.cfg in var/etc folder it is editable and not corrupt. The gz file can be extracted on the PC and seems to install OK. Where can I get a good gz file to reinstall again
    DK Veteran freck's Avatar
    Jul 2008
    Dark side of the Moon
    Dont add CCcam 2.3.0 to any receiver....be warned!!!!
    Freck
    Aug 2012
    Default Why ...
    Why are you warning? What is the problemwith CCcam 2.3.0?
    Quote Originally Posted by freck View Post
    Freck
    Jul 2008
    Quote Originally Posted by elturco2000 View Post
    http://www.digital-kaos.co.uk/forums...talled-248707/
    Freck
    Dec 2012
    I've found CCcam 2.3.0 an was going to take 2 files i need an flash it but ive just seen you said dont use this CCcam 2.3.0. What would you suggest i do please any idea?
    Oct 2012
    whats wrong with it
