Page 88 of 88 FirstFirst ... 3878838485868788
Results 1,306 to 1,319 of 1319
  1. #1306
    May 2009
    I have X100 long time I dont use it loss SD cart any link can download sd cart
    thanks in advance
  2. #1307
    Feb 2014
    Try to put new card inside, then use the tool software on your PC to download last available updates for it.
  3. #1308
    May 2009
    Dear I try all
    but no way maybe its clone or....
    any other cart dont work ...?
  4. #1309
    Oct 2018
    does any one know where they store the eeprom saves on it so it can be downloaded? also wouldn't recommend this to any one in the EU it does the job on some but not all FVDI on the other hand works amazing.
  5. #1310
    Feb 2019
    NIGERIA
    Can the xtool x100 pro add a new key for 2006 infinity fx35 smart key and 2009 Hyundai tuscon remote ?
  6. #1311
    Feb 2019
    NIGERIA
    just install an new SD card in the programmer, download the upgrade tool from the website, install it and start up the upgrade process. This will automatically install all lost files.
  7. #1312
    Feb 2019
    NIGERIA
    Quote Originally Posted by hrag View Post
    thanks in advance
  8. #1313
    tiguan's Avatar
    Sep 2009
    I also have a problem with the TF Card. X100 pro
    I have tried everything via Xtool site upgrade tool does not accept the login and password.
  9. #1314
    Dec 2018
    You need a usb micro card reader/writer. There you download the files. After that put the card back to the x100.
  10. #1315
    Dec 2018
    O no, sorry. I was wrong.... Go to the "about" menue, there is the password.
  11. #1316
    Dec 2019
    I know this is an old topic, but who can tell me: Can the X100Pad with eeprom adapter odometer the Hyundai Grand i10? Thank you
  12. #1317
    Dec 2019
    Put a look in the pdf in eeprom section
  13. The Following User Says Thank You to Poulpy For This Useful Post:
    Alesk (14th April, 2020)
  14. #1318
    Jun 2015
    United Kingdom
    Quote Originally Posted by Alesk View Post
    Car list for u https://www.xtool.co.uk/upload/pro/2...8408548467.pdf
    In fact x10pad can't
  15. #1319
    Jun 2015
    United Kingdom
    Just wanna share the latest update info about xtool scanners here.
    Tablet Series Car Diagnosis HONDA V11.40
    2021-04-28
    Languages Supported: Russian, German, French, Portuguese, Spanish, Polish, English, Traditional Chinese, Simplified Chinese, Italian,Vietnamese,Arabic
    Update:
    New Features:
    1.Engine System Adds Special Function "Calibration Of Motor Rotor Position";
    2.ABS System Adds Actuation Test "Modulator Bleed" and Special Functions "Brake pressure sensor group","Sensor Cluster","Writing Steering Angle Sensor Center Point" and "Deflation warning system";
    3.ACC System Adds Actuation Tests "Opening Angle Of Throttle","Brake Booster 1","Brake Booster 2","Brake Booster 3","Information Display","Collision Mitigation Brake System (CMBS) Brake" and "Light Check";
    4.Super Handling-All Wheel Drive(SH-AWD) System Adds Actuation Tests "Oil Pressure Test Of Shift Solenoid","Test Of Transfer System" and Special Functions "Calibration Of Transfer Driver","Calibration Of Transfer System","Transfer Oil Life Reset" and "Calibration data clear";
    5.Smart H Adds Special Functions "Have Knob Ignition Replaced","Loss Of All Keys","Add One Key","Keys Rewrite" and "Customization";
    6.Drive By Wire(DBW) System Adds Special Function "Reset Of Engine Control Module (ECM)/Powertrain Control Module (PCM)";
    7.The FCVSCM System Adds Actuation Test "H2 Line Pressure Relief Mode";
    8.CAN Gateway System Adds Actuation Test "F-CAN Bus Connected Unit Check";
    9.IMA System Adds Special Functions "High-Voltage Battery Diagnose","State Of Charge (SOC) Preset" and "Replacement Of IMA Electronic Control Unit (ECU)";
    10.Meter System Adds Special Functions "Maintenance reminder device (US market)" and "Maintenance reminder (European market)";
    11.Precision All Wheel Steer System Adds Special Functions "PAWS unit replacement".
    Optimization Functions:
    1.Optimize Automatic Scann Function;
    2.Optimize The System Name and Software Icon.
    Fixed Problem:
    1.Fix the problem that no datastream in the 2004-2007 Fit Anti-lock braking system;
    2.Fix the problem that the trouble code cannot be read in the 2008 Accord anti-lock brake system and the 2007 CRV;
    3.Fix the problem that the special function "All Sensors" of the 2018 Accord anti-lock brake system failed to execute;
    4.Fix the problem of 2013 CRV Airbag initialization failure;
    5.Fix the problem of incorrect datastream value of 2003 Odyssey engine system.
