Results 1 to 4 of 4
    Default Renault Kangoo _ 1.5 DCI _ DCU3R
    I need the original dump for this ecu.
    DDCR 80931H
    R0410c042a
    8200212346
    hom8200114905
    Flash - 29F200BB.
    If you have any file on this reference.
    I need a file that has the pcb as the image. The pcb reaches the end of the housing.
    Normally all these ECU just 3 or 4 cm before.
    Attached is a photo of the ECU are for the same car. But they are not compatible flash mount the ecu I need.
    Nov 2013
    Hello, I see that you had a problem with reno kangoo 15 dci and am now so if you could send me the original dump for this ecu
    delphi
    ddcr 80931h
    s No 0005986 cv6
    8200212346
    hom 8200114905.
    Thanks in advance.
    LaraVAG's Avatar
    Jun 2011
    try this file
