Page 1 of 3 123 LastLast
Results 1 to 15 of 36
    Senior Member cboyer's Avatar
    Feb 2012
    Default cant connect to ftp
    this is doing my head in ? i cannot connect to dreambox using flash fxp or dreambox control centre i have turned the firewall off i can connect to dm 800 fine? is it different for 500s? username root ?pw dreambox?
    "I've got it made. I've got a wife and a TV set -- and they're both working."
    Nov 2010
    Maybe someones changed the password on it, I take it the ip is correct.
    plasterer's Avatar
    Jun 2008
    Mersyside
    Is it a wired connection or wireless
    if wireless make sure dchp is checked
    Hope this helps ............Paul
    PAUL
    Feb 2012
    nah mate nobody could have changed p/w as i bought directly from china the wierd thing is that when i press on remote setup/expert setup then communication setup ip the ip says it is 10.0.0.97 which seams an odd ip ?
    Feb 2012
    it's a wired connection pal?
    V.I.P. soft lad
    Mar 2008
    in a house
    go into network settings on box un-tick dchp and give it a
    static ip thats on your lan ie 192.168.2.xx
    Feb 2012
    hiya elric bud unticked dhcp typed in an ip of 192.168.1.2 then clicked save then on dcc i typed same ip for dreambox but still wouldn't connect ?
    V.I.P. Member Fergal's Avatar
    Aug 2008
    Is the ip you gave it in the same range as your pc also try ticking dhcp and save then reboot the box and see if it gets a proper ip.
    Feb 2012
    Quote Originally Posted by Fergal View Post
    yer mate i think so ?
    Feb 2012
    ticked dhcp rebooted now ip gone back to ip 10.0.0.97?
    Feb 2012
    is there another way to get sealion and bouquets on?? or have i just got a box that has a few freeview channels ? i can't even flash a new image can i ?
    DK Veteran freck's Avatar
    Jul 2008
    Dark side of the Moon
    Quote Originally Posted by cboyer View Post
    Set an ip on the box like 192.168.1.99 and set your lan to 192.168.1.100 and try to connect with a crossover cable...disable dhcp on your box.
    You box aint getting an ip addy from your modem???
    Reboot your modem and your box and see if its gets an ip via dhcp if the static ip dont work out.
    Freck
  13. #13
    V.I.P. soft lad
    Mar 2008
    in a house
    Quote Originally Posted by Elric View Post
    did you reboot network in the same settins after you gave it a static ip,also its not the same ip as other things on your lan
  14. #14
    Feb 2012
    nothing is working piece of sh1t my openbox is working plugged into same ethernet cable
  15. #15
    V.I.P. soft lad
    Mar 2008
    in a house
    unplug the open box and any other boxes connectin to your lan,and try again,set a static ip,save it,restart network
    also look in your router status page and see if your box shows in there and see what ip addy it has
    theres nothing wrong with dm500s its the user
