Results 1 to 15 of 15
    DK Veteran lee_hdi's Avatar
    Sheffield
    Default Astra H 1.6 Z16XER Non-Start
    My friend has a 2007 Astra H 1.6 (Z16XER engine) and it won't start, doesn't even crank. All dash lights come on, but won't start.
    He took it to a garage who checked the earths, power, starter relay, starter motor, and it wouldn't even let them connect the laptop up to see if that shown anything, it just said "no communication".
    So the mechanic said he thinks the ECU is no good, and suggested a replacement and he's been quoted ?800.
    So I was just wondering if anyone else had any ideas what it might be?
    If the ECU does have to be replaced, would he be able to get a second hand one and pay someone to transfer the IMMO data from the existing to the replacement, and then just program the new VIN number in with op-com?
    This is his ECU
    I've had a quick look on google and found this company who reset ECUs...would that be sufficient for a second hand one? - Vauxhall Opel Simtec 75.1 75.5 and 81 ECU Reset & Pin Extraction - Cartech Electronics
    I've not seen the car as he lives over the Pennines, so just going on what he's said on the phone.
    Don't let failure go to your heart, don't let success go to your head.
    Ashraf6119's Avatar
    UK
    Have you checked if it will communicate with all other ECU's..........?
    What is the story about this vehicle...........did it just die or, they working on it and it didn't start..........
    Also check the earth wire on Engine ECU for poor connection........
    http://www.ebay.co.uk/itm/06-MK5-AST...item27c6037cc8
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    Sheffield
    The earth from the ECU has been checked, that was one of the first things I told him to check when he rang. He said the mechanic even tried 'piggybacking' all the earths with fresh wire just to double check.
    It won't communicate with any ECUs. Just text him to double check that.
    The car started then chugged and cut out, then wouldn't crank or do anything.
    Hi biggest fault on these is the the under bonnet fuse box done 4 all same fault. mulitpal fault codes on a complete scan
    Sheffield
    Quote Originally Posted by mmcd View Post
    It doesn't even let you run a scan though.
    Meat-Head's Avatar
    1) What wireless does it have? Standard or after thought?
    2) look side of battery and fusebox, low low down earth point had one, no nut on it from factory.
    2a) what about warning lights, they on/working?
    2b) hold a chicken in the air, stick a deckchair up your nose and try jump lead from
    engine block to battery neg
    3) OFF TOPIC:-
    Are your security codes free or insert coin?
    (reply by pm if you have to)
    Meat
    May 2009
    Steering column function control module or multifunction unit fault/corruption of comms to the ecu/rest of car?.....follow the wiring diagrams/eliminate things
    Apr 2012
    First check Can network wires "can"- hight;"can" low with ociloscope!
    many cars have this problem
    Ashraf6119's Avatar
    UK
    Does instrument lights come ON when ignition is switched ON
    Thanks Ash
    Sheffield
    3) OFF TOPIC:-
    Meat
    Warning lights come on, and he said that all the earths have been checked. Also told him to try doing his own earth from the -ve.
    Wireless?
    Quote Originally Posted by obd.tech View Post
    As far as I know, that is working fine.
    Quote Originally Posted by Ashraf6119 View Post
    Yes they come on.
    I've told him to go get a second opinion off another mechanic, as I can't go till probably Sunday to have a look
    Meat-Head's Avatar
    Quote Originally Posted by lee_hdi View Post
    Wireless?
    1) Thanks for the PM
    2) RADIO - old fashioned term for radio
    3) OFF TOPIC:-
    See a thread the other day the word 'accumlator' was used - cool
    word for battery
    4) ON TOPIC:-
    Suggest an auto sparky or indpendent vauxhall specalist.
    DK Veteran ghostridersa's Avatar
    Nov 2011
    I have experienced this same problem before and it turned out to be the CIM unit on the steering column which was faulty.
  13. #13
    Nov 2011
    Have you solved the problem yet? Would like to know what you found wrong.
  14. #14
    alclot's Avatar
    Melee Island
    HI mates,
    Sorry to recover this old post. I´m looking for the full flash dump from same reference. Can anyone help me please?
    thanks in advance
  15. The Following User Says Thank You to alclot For This Useful Post:
    Meat-Head (16th April, 2021)
  16. #15
    Meat-Head's Avatar
    1) nice to see recycling
    2) buy used ecu off eBay
    3) sorry no idea where €20 buy flash file standard off a website
    4) can dealer flash it for you
