Results 1 to 10 of 10
    DK Veteran andy211081's Avatar
    May 2009
    Doncaster
    Default Mgcamd needs restarting all the time
    I have installed new vix image, i watch a channel and its fine ten mins later i change channel and its black so restart cam and sometimes work if not i have to restart box just to get it to work!
    Anyone any ideas?
    Andy
    Ladies and Gentlemen, this is your captain speaking. I have the only gun on board. Welcome to Con Air.
    Mar 2012
    Which Mgcamd version are you using?
    I have 1.35 installed on ViX 2.4 but have been using CCCam so havent tried it.
    May 2009
    Doncaster
    1.35 will try a diff version
    DK Veteran potrobber's Avatar
    N Ireland
    did you install mgcamd thru tspanel emu manager by any chance ? as this causes the problems you have
    also what settings you got for ( g ) (k) ( p) and ( b) in mg_cfg ?
    May 2009
    Doncaster
    I tried adding thru tspanel but it wouldnt work so i found one for vix on here so installed that one.
    Some channels clear ok, some beed the box to restart, and recording is not working! I know the image is a work in progress so will jusy have a play around!
    May 2009
    Doncaster
    Quote Originally Posted by potrobber View Post
    I will have a look at cfg tomorrow
    Mar 2012
    I can uplaod my mg_cfg if needed which appears to be working.
    May 2009
    Doncaster
    I altered the mfg to replace 0 with 6 at line 131!
    Channels clear but it takes about 10 seconds! Does anyone have any ideas?
    N Ireland
    m8 change g to 33 ,, b to 06 ,,k to 07 then see how it goes
    also are you using c or n lines?
    May 2009
    Doncaster
    i am using n line ..i have changed cam from 1.35 to 1.38 to see if that will help also
    thanks for advice will do that also
