Page 1 of 13 12345611 ... LastLast
Results 1 to 15 of 184
    May 2012
    Under the cosh
    Default Duo clone broke this afternoon!!!!! Help
    Box is couple of days old. Left it last night to try and get epg loaded.
    Today clock showing on front panel, but will not respond to remote.
    Turned off at back.
    Upon turning on just shows red boot light top right and nothing else. Will not boot, not matter how many times I power cycle.
    Help!!!
    BTW, I did not try and reload any images on it. All I did last night was to try and get the UALS sorted and get the 7-day EPG setup onto a USB pendrive overnight.
    It looks totally bricked to me.
    DK Veteran potrobber's Avatar
    N Ireland
    m8 ii have put posts on here before about the clones i open everyone now and push all the connections fully home
    i have even had a couple with the main lead from psu not pushed in at all so open your box and check all cable connections are fully home this im sure will be your problem
    May 2012
    Under the cosh
    Quote Originally Posted by potrobber View Post
    Thanks I'll try this again. But I did have a look at all the connectors when I fitted the hard drive, as I'd seen your posts before.
    Will let you know how I get on.
    N Ireland
    try pulling all the connectors apart first then refitting them just to be sure
    May 2012
    Under the cosh
    Tried this mate.
    Connector to main board.
    Fan to main board.
    Removed drive connectors (to take out of equation)
    Connector to front panel.
    Etc
    Basically every one I can see that can be disconnected was removed/reconnected.
    Still only see red light on front. This goes amber when remote is pressed but that is about it.
    Its noticeable that the fan is not spinning on power up. Could this be a heat issue causing the power supply to cook?
    Last night was the first time I left the unit running overnight, albeit in standby ,awaiting epg update. Looks like cross epg files on pendrive were updated at about 2am. So could it have cooked after then?
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    I have read a thread about the red light on duo somewhere and something about C807 220UF capacitor on board needing replaced. Also the flash may have been erased.
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Yes this is the one. What image were you on before it broke and was everything working ok.
    N Ireland
    there is also a fix for red light stuck on, on ferrari forum for bricked box have a look there m8
    i dont think leaving it on would cause this as i never turn them off
    May 2012
    Under the cosh
    Quote Originally Posted by DOUGALMCD View Post
    I've only had it running for about a day. I think it was preinstalled with BH 1.70
    Yes it was working, although I was having problems getting it to properly drive my technomate motor via USALs (see other post from yesterday
    The crossepg stuff appears to have been downloaded about 2am.
    Looked at that thread and a few others. Seems it may not just be that Capacitor. Another guy had to replace the Power supply
    Is the fact the fan is not moving an indication of that also broke?
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Have you tried to reflash with fresh image on front usb.
    Make sure you use duo file
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    It sounds to me as if the box has had some sort of corrupt file and just needs to be reflashed.
    Did you format usb to fat 32
    Did you mount usb in settings
    Did you put usb in front or rear
    May 2012
    Under the cosh
    Are you talking about a new version of BH or VIX? Or a complete new kernel. If so isn't that done via the serial link on a clone (which this is)
  13. #13
    May 2012
    Under the cosh
    Re second set of questions
    Pendrive was formatted Fat32
    It was put overnight in rear of box
    I didn't mount anything, but the crossepg files did make it there at 2am as I say above
  14. #14
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    If you had bh 1.7.0 you should have the latest kernal.
    Did you flash box yourself and it should say v2 somewhere on box.
  15. #15
    May 2012
    Under the cosh
    I'm a newbie here and only got this box a few days ago. I have not tried to flash anything so far.
    Yes it has a V2 sticker on the back
