Results 1 to 5 of 5
    Top Poster poppyjack's Avatar
    Jul 2011
    Leicestershire
    Default HomePlug Ethernet Adapter
    Have got a set of HomePlug Ethernet Adapters, one plugged into my router and the other one is downstairs and working perfect, my question is, can I buy a single Homeplug and put that in another room and have it working from the one plugged into my router?
    Many thanks.
    Top Poster tigger001's Avatar
    Feb 2009
    Midlands
    The answer to your question is Yes . Once you have set up your original Homeplug network adding others is not a problem.
    Jul 2011
    Leicestershire
    Thank you tigger.
    Nov 2008
    does it matter if the extra one is not of the same make? So if i use 2 develo homeplugs and 1 netgear homeplug would they all connect?
    Top Poster + ka-pa-za's Avatar
    Not sure,
    I have 3 powerlan 200 (devolo)
    And 1 belkin 200av,
    but the belkin don't work with the devolo
    So better ask your vendor if you may return if it is not compatible. or don't risk it and buy the same.
