Results 1 to 14 of 14
    Slovakia
    Default Turbo charge control circuit malfunction
    hi
    I have a problem with Peugeot 407 2.0 HDI RHR
    , during the driving engine stop and run (it returns often)
    fault codes:
    P1693
    SID 803 Starting and switching off of the engine controlled. Starting or switch-off requests absent or not valid.
    U2001
    SID 803 Multiplexing. Remotely controlled triggering information not coherent. (CAN)
    U1118
    SID 803 - Receiving fault. Multiplexing. No BSI or air conditioning communication.??( with ECM).
    thank you for the help
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    sounds like the turbo is seizing up there not like a normal turbo .. cant remember the name now , but there loads on youtube about them .., someone will know the name
  3. The Following User Says Thank You to smirnoff_rules For This Useful Post:
    Nanu (13th October, 2013)
    Ashraf6119's Avatar
    UK
    P1693 fault code according to AD its for Starting or switch-off requests absent or not valid.........and nothing to do with your Turbo charge control circuit malfunction............
    You need to check the wiring from Starter Motor to the Fuse box in Engine bay also the relay for starter motor which is build in that fuse box, and those fuse box are common faults for starter problems.......
    Hope this helps...........
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
  5. The Following User Says Thank You to Ashraf6119 For This Useful Post:
  6. #4
    Meat-Head's Avatar
    Quote Originally Posted by smirnoff_rules View Post
    VNT15-Turbo
  7. The Following User Says Thank You to Meat-Head For This Useful Post:
  8. #5
    chacarita's Avatar
    Argentina
    please upload the vin number of these car
  9. The Following User Says Thank You to chacarita For This Useful Post:
  10. #6
    Slovakia
    Quote Originally Posted by chacarita View Post
    ok, i will upload it on monday
  11. #7
    Slovakia
    sorry for the delay,
    the win number is: VF36ERHRH21069990
    the car is Peugeot 407 2.0HDI 100KW 2004 year
    the problem is, during the driving engine stop and run
    this fault occurs regularly about after 500 KM
    what could be the problem? thanks for help
  12. #8
    chacarita's Avatar
    Argentina
    check this:To or from: 407 TURBO DIESEL AND DW10BTED4 FAP to OPR OR 11040 407 TURBO DIESEL AND WITHOUT DW10BTED4 FAP to OPR 11040
    Customer Impact: Lack of circulating total power, prompting the vehicle stop, the engine continues to run at idle until it stops; During the action of restarting the engine still warm: Normal operation
    Conditions of occurrence: Circulating
    1. origin
    The double gasps air dispenser in closed position.
    2. intervention After Sales
    Dual control box air dispenser.
    2.1. Parts Needed
    1 Box dispenser double the intake air (F0 reference PR 0345) (if necessary).
    2.2. control
    Remove: The double dispenser air.
    Control the number recorded in the double box air dispenser:
    If the reference is 96575224 Part 80: Intervene
    If the reference piece is different from 96,575,224 80: Continue with the diagnosis
    2.3. intervention
    Replace: The double dispenser air.
    Install: The double dispenser air.
    2.4. Reaction time
    Time: 0.50.
    Operation Code: 03242A.
    3. solution series
    From the number of OPR 11041: Application series.
  13. The Following User Says Thank You to chacarita For This Useful Post:
  14. #9
    Slovakia
    This is that double air dispenser?
  15. #10
    Aug 2011
    Europe
    That is the bypass of the air from the intercooler , normaly works during the regeneration of the Fap.
    I think you have a eletric problem in wires
    Please check again the fault codes .
    regards
  16. The Following User Says Thank You to kastissu For This Useful Post:
  17. #11
    Slovakia
    Hi, the faults are:
    U1118 - No BSI or air conditioning communication
    - Intermittent
    P1693 - Controlled start and stop off the engine. Starting or switch-off requests, absent or not valid
    - Intermittent
    U2001 - Remotley controlled triggering information not coherent
    - Intermittent
    P1598 - Cooling circuit bypass valve
    read with AUTOCOM (clone) Lexia read similar
    In my view the problem is that, what chacarita wrote
    but I'm not sure I am testing the car...
  18. #12
    Aug 2011
    Europe
    - Intermittent
    - Intermittent
    - Intermittent
    well In my opinion this 3 faults codes are related with comunication or configuration between BSI and ECU of engine.
    This one is the bypass of the intercooler, check in atuactor function if is realy working ...
    regards
  19. The Following User Says Thank You to kastissu For This Useful Post:
  20. #13
    hi
    I've got the same problem
    Did you find the solution?
  21. #14
    Slovakia
    Quote Originally Posted by bahlawi View Post
    hi
    Yes, I changed the double air bypass valve, and two air valve which is directing the vacuum , the car thence works well!
    (it doesn't stop and run during the driving)
