Results 1 to 10 of 10
Thread: changing ecu
    KILL_THE_IMMO's Avatar
    spain
    Default changing ecu
    hi all
    just a simple question
    i have a partner 2001 ec 0 261 206 862 m7.4.4
    it can be changed by
    0 261 206 944 me7.4.4 ?????
    --------HELP OTHER TO BE HELPED--------------
    spain
    i plug this second ecu with his bsi and key but car still not start, immo light go
    the problen can be that 962 is diferent of 862 try to ptogram the key again if the keys cant be program , dont work in this cr whith immo on but could works whith immo off
    chacarita's Avatar
    Argentina
    do you try swiching memories?
    spain
    I FIND IN THE INTERNET A TECHNICAL DOCUMENT OF ME7.4.4 AND M7.4.4
    SO IT HAVE THE SAME DIAGRAM
    spain
    i tested the second hand ecu with full kit (key and bsi)
    immo lighr off and car wont start
    the car dont have any other problem just key loosed and i want to program another
    Jun 2009
    On PSA autos must very atension with disconnect aku, is special procedure, only on sleep mode BSI. Flash chip and eeprom you copied?
    spain
    no i dont need to copy ichanged full kit but dont work here i ask if these two ecu are compatible or not??
    if not where is the immo in the first ecu in eprom or in flash??
    chacarita's Avatar
    Argentina
    inmo is in flash
    chacarita's Avatar
    Argentina
    best solutions is make flash it remember maybe 95160 put it virgin and reprog like new ecu,
