Post the ori read from car, and the bdm flash read i will rebuild it
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
Thank you, attached.
file here write bdm
Fermounth (31st January, 2020)
this will work, i killed one just the same
"I always tell the truth. Even when I lie"
"We Taking Over, One City At A Time"
long time meaty, took a hint u see
bricked it trying to save time, spent hours fixing it in the end
what tool have you used and what is the reason for fail?
Genuine Magpro - wrong soft version flashed.
magpro cant recover ppd? i failed few times when writing PPD, and MPPS recovered it without problems every time
MPPS couldn't recover this either as the ECU won't even wake up.
I`m read PPD = MPPS
No problem
once the wrong versions flashed in the immo kicks in
no security access allowed
So in the end it's not the tool but the tool user
