Results 1 to 5 of 5
    DK Veteran uchtool's Avatar
    Dec 2010
    Default bmw e90 Automatic Air Conditioning Control not work
    hello!
    I have bmw e90 diesel year 2010 have Automatic Air Conditioning Control not display and not work!
    I made diag and get all this atached errors fault!
    I have changed other air conditionning control, but not work too!
    my question is:
    if I remplace this Automatic Air Conditioning Control, it need some coding?
    JBE must be coded if I change it with an others?
    you think jbe is cause for that?
    Faults: + C914 JBE: No message (K-CAN: status, A/C, 246)
    see others error in attached text.
    please help me, what must do now?
    I need your advices
    Dec 2010
    any help there?
    Dec 2010
    where is the experts with bmw?
    Staffs UK
    get a wiring diagram of the K line
    disconnect one component at a time until comms are restored
    put a scope on the K line and monitor for signals and check it isn't short to gnd or +ve (except when comms starts up for a very short period)
    Just FYI:- I think aftermarket radios used to put 12v on the K line of early VW (which is why VCDS is protected against it) and caused all sorts of other problems
    Mar 2024
    alguna ayuda del clmatrinic
