    Netherlands
    Default Help DPF Focus 1.6Tdci
    Need some help with DPF off for a Focus 1.6TDCI.
    The file I made throws P1187 code, that should be related to cruise control.
    Attached the ori and my mod.
    Thanks in advance.
    spawns3's Avatar
    Portugal
    Manually solution mate ask a reputble member , maybe he can help you
    Netherlands
    Yes I know, that's what I did.
    I think I found it, test it in the morning.
    Netherlands
    With original soft car gives the same code P1187, so the fault was already there before the DPF mod.
    They don't tell this of course.
    May 2012
    italy
    Default focus erros
    Quote Originally Posted by easytech View Post
    this problem is not chiptuning , but is mmps the problem
    read on bdm and redump all on bdm erase can error all ecu! and drive! is a psa engine ... recode iniectors
    if you are original bdm dump or find dump without quadriprom (key code)
    the same problem solved
    or with wsc in ford redump all then bdm.
    Netherlands
    Can't follow what you mean.
    Dump is CMD OBD ori-master.
    Re-coding is for older C31 ecu's I tought.
    I'll do a reflash with IDS next week.
