Results 1 to 9 of 9
    Czech Rep
    Default Calibrate speedometer impulse in dump VWT4
    Hello all,
    who can help me please with correct different in speedometr. I have one T4 with dash from Passat B5,5 3B0 920 847 D, wheels on this car are 215/60 R17 and tramsmision is upgraded from sharan 6Q. And now is really speed about 25% higher then in sppedometer.
    Can You help me please anybody?
    Many thanks
    Matias
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by matias View Post
    Hello all,
    Many thanks
    Matias
    Eat a cup of tomato soup, remove the speedometer needle with the spoon afterwards and adjust it. Ready...
    Junior Member planktom's Avatar
    Nov 2011
    black forest
    Quote Originally Posted by drpeter View Post
    and do that just for every speed you wanna do
    i think it must be possible just to code the cockpit
    greets : tom
    "Sent from my iPhone"
    ...made of rare metals 90% coming from businesses using slaves and children to reduce the ores
    DK Veteran zeljolaki's Avatar
    In my garage
    Plug VAG.Com and see how it is coded
    instrument panel.
    The last digit should be 3, and again control the speed.
    Good luck!
    Czech Rep
    Hi drpeter I haven?t spoon for eat, I have only spoon engine honda and I can?t use this for remove dash from car.
    But many thx for very good help.
    Meat-Head's Avatar
    cool, can you try leeching a passat dump then IN-correct the miles.
    Czech Rep
    dash is coded 00103
    Top Poster Lidahus's Avatar
    Feb 2012
    Jamaica
    I don't think that you can adapt dash by a standard factor stored in EEPROM. So just changing dash code will not help. You have to measure pulses per km and change the factor in EEPROM accordingly.
    Czech Rep
    Lidhaus,
    I know when is imposible change measurment per coding. I use all coding for dash, but without lucky.
    When I know in which address is speedometer scale I change this value, but I don?t know where is this.
    You know this?
    Many thanks for help
    Matias
