Is posible with winols.
Your file with checksum.
Real engines don't need forced induction
Who needs a turbo when you have a stupidly quick naturally aspirated engine?
Solved......
Checksum no correct, mpps checksum not ok.
greetings
mpps doesn't work on edc17. It changes cks zones in writing and car doesn't start. Read and write ecu with another tool
so the problem is not the file, its MPPS??
yes friend
thanks all for response.
MPPS writes until it goes to 75% and then gives a checksum control error or so and the car will not start. When you flash back the ori file it goes to 100% and all is fine again.
I got the same Problem on a VW Passat EDC17 with MPPS 3.0.2.37.
Is VAG EDC17 Possible with V12 ???
Or better buy a Galletto 2 Clone?
better buy a Galletto 2 Clone!!!
Here you go...
Pass in pm
