Results 1 to 8 of 8
    May 2012
    Default Newbie Q - updating ccam from DK1.1 image?
    Can anyone help?
    I've flashed the DK 1.1 image on my dm500s clone.
    I've added the Astra 28.2E satellite/transponders
    I've update the bouquet.
    So I've got a very nice FTA box, with a good menu system.
    I'd like to have a play now.
    So how do I add the cccam 2.1.4 files? I've copied them into the tmp folder on the box (via ftp), and tried to do a manual update, but that doesn't work.
    Any pointers would be appreciated.
    Ta.
    Mar 2012
    you don't copy them m8 you transfer them the file saved in your computer will be on your write hand and the files on your box will be on your lift just use the arrow to transfer between the computer and the box in the temp folder then do manual install should work
    Jan 2009
    Quote Originally Posted by blokeupnorth View Post
    Can anyone help?
    Ta.
    what do you mean when you say it does not work? you still only getting fta? then that is correct. you need a sea lion to get more channels
    May 2012
    Quote Originally Posted by gemihema View Post
    OK - thanks - I'll try again.
    May 2012
    Quote Originally Posted by mark8393 View Post
    I mean I can't see the latest cccam to upgrade to.
    I presume I need cccam 2.1.4 for use sea lions?
    May 2012
    I must be a right numptie - I've tried to transfer the files across using DCC - but just won't transfer.
    I tried Filezilla also and no joy.
    I presume it is the "tmp" file in the root folder, and I transfer across CCCAM.ppc ?
    V.I.P. Member chic.'s Avatar
    Feb 2009
    glasgow
    hi m8 welcome to the forum
    you transfer the CCcam to var/bin .
    May 2012
    Quote Originally Posted by chic. View Post
    Thanks - ill give that a try
