Results 1 to 7 of 7
    Harrycz44
    Guest
    Default Fabia 1.9 74KW 019NE
    Hello I want tuned Skoda Fabia 74KW vw nr. is 019NE Can I use files from Seat Ibiza with same vw nr. 019NE???? thanks
    Sep 2010
    YES SURE SKODA SEAT VW AUDI
    spawns3's Avatar
    Portugal
    Quote Originally Posted by Harrycz44 View Post
    Why u don't tune the original file ? There is a good EDC15 tunning Guide.
    you might get lucky and by coincidence yes, But checksum could be different, map values..,etc. you could block the ECU.
    I would first open both files to check diferences, and see if checksum differs
    UK
    yes,definetly....espically if difference vag group...
    May 2012
    Yes you can. Check that HW and SW number are the same, after that you can tune and write that file.
    Only a question: why you haven't the original file from skoda fabia? I think it's more easy to read it.
    Harrycz44
    Guest
    Thank you all for tips.. I try it maybe will work o)
